bent rim/suspension question.
Old 04-14-2014, 10:09 AM
greyEG's Avatar
Default bent rim/suspension question.
Sup guys, hit a pot hole big as f*ck. And i was wondering if you bent a rim or a control arm or tie rod, would you be able to feel it while driving?
( Like is it noticeable or you really have to pay attention?)
What is a sign that your wheel is out of balance. ( maybe i lost a weight on the rim )
Sorry guys just worried something f*cked up!!
Thanks!
Old 04-14-2014, 10:13 AM
JuggerNaut-CTR's Avatar
Default Re: bent rim/suspension question.
Should be able to feel a bent suspension component under a certain speed or under certain engine load, if it's bent enough.
Take the car to a wheel/tire shop and have them spin the wheel to see if it's bent and re-balance it.
Wouldn't hurt to have the alignment checked after the wheel is spun too.
Old 04-14-2014, 11:49 AM
95Sedan's Avatar
you would feel bent parts or rim, the parts would make it pull to one side,
bent rim would make it feel like you have a squirrel or other stuck to the tire and lump a bit.
haha I would take it to a shop and have them look it over for loose suspension parts, if not balance the tires and get an alignement. never hurts.
Old 04-14-2014, 12:57 PM
93egSLEEPER's Avatar
Just give it a good once over. Suspension should be tight in all directions. Check for a separated tires as well.
Old 04-16-2014, 03:33 PM
greyEG's Avatar
bump any more answers?
What speed should i be testing at?
D16SohcVtec
Suspension & Brakes
04-03-2009 08:04 AM
Bantam
03-24-2003 01:27 PM
vtec94
09-04-2002 11:20 AM
Quick Reply: bent rim/suspension question.
