Ball Joint help..search already
Old 03-07-2009, 04:16 PM
halocore's Avatar
Default Ball Joint help..search already
Does anyone have a DIY for replacing the front lower ball joint. My threads are striped so I'm trying to replace the lower ball joint but i have no idea how to take out the old one... do i just hammer it out?
Old 03-07-2009, 04:34 PM
jadziasman's Avatar
Default Re: Ball Joint help..search already
To get the ball joint loose from the lower control arm you need a ball joint separator or you can use a trick you can view on YouTube. Search for Honda Civic lower ball joint and the video should pop up.
It's not the easiest of jobs for a novice mechanic to remove and replace the lower ball joint on the 92 - 95 Civic. Unless you are willing to buy/rent some tools, you're better off getting a mechanic to do it for you.
If you want to DIY, then yes you will need to get a 5 lb hammer and whack it out of the knuckle. It's a lot of fun! I just did one yesterday.
Hexar
23
05-20-2009 06:43 AM
89efhatchcrap
Suspension & Brakes
24
02-17-2009 10:36 AM
munoz86
12-04-2008 03:59 AM
2camsaam
21
10-01-2003 07:32 PM
97hb
03-09-2002 11:31 PM
Quick Reply: Ball Joint help..search already
