Bad main relay?? fuel pump primes everytime after it cranks over, wont start though
?? as stated in the title, i hooked up an extra ground wire from the power steering mount to the chasis since in my searching it said possibly bad ground,
i borrowed one freinds main relay and it didnt work, maybe i should try another??
Mr. Badwrench
Re: Bad main relay?? fuel pump primes everytime after it cranks over, wont start though (itr#xxxxliv
an engine needs 4 main things to start:
(and compression for you perfectionists. but this will suffice)
1 - fuel
2 - air
3 - spark
4 - and correct timming
you have fuel, and hoping that you have air,
check for spark, and if you have that, if the engine is sound, it has to be timming. possible that the belt jumped.
1 - fuel
2 - air
3 - spark
Re: (Jimmy)
i have a 94cx, 99 ls swap with itr tranny,
the fuel pump wont prime when i turn the key to the on position, sometimes it will take a couple seconds it will prime and the main relay with make a click sound, i try to crank it over and it wont start but when im done cranking the fuel pump will automaticaly prime again
sometimes there will be cracking sounds coming from the main relay, im thinking its the main relay or possibly some fucked up janky *** wires somewhere
Re: (itr#xxxxlives)
the 99 ls motor is fresh, never been touched, ran in the wrecked car before pulling out, also the car would start a few days ago, but its just sat for a couple days waiting for its exhaust appointment(Which is tomorrow if the dam car will start and run)
Guest
Posts: n/a
Global Moderator
http://www.marklamond.co.uk/ho...y.htm
<FONT COLOR="red">-----</FONT>
http://autorepair.about.com/cs...1.htm
Re: (itr#xxxxlives)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by itr#xxxxlives »</TD></TR><TR><TD CLASS="quote">the 99 ls motor is fresh, never been touched, ran in the wrecked car before pulling out, also the car would start a few days ago, but its just sat for a couple days waiting for its exhaust appointment(Which is tomorrow if the dam car will start and run)
damn same thing here except its a civic
Re: (ek_b16)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mike93eh »</TD></TR><TR><TD CLASS="quote">here is where i got the info. i had a couple dry joints...
http://www.marklamond.co.uk/ho...y.htm</TD></TR></TABLE>
awesome info
awesome info
Re: (itr#xxxxlives)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by itr#xxxxlives »</TD></TR><TR><TD CLASS="quote">dam i re solderd all that **** but it still does the same thing, has to be a bad wire somewhere...
I u want i got an extra main relay if u need it. lmk
Re: (itr#xxxxlives)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by itr#xxxxlives »</TD></TR><TR><TD CLASS="quote">the fuel pump wont prime when i turn the key to the on position, sometimes it will take a couple seconds it will prime and the main relay with make a click sound, i try to crank it over and it wont start but when im done cranking the fuel pump will automaticaly prime again
sometimes there will be cracking sounds coming from the main relay, im thinking its the main relay or possibly some fucked up janky *** wires somewhere</TD></TR></TABLE>
pick up your trusty multi-meter. check the following at the main relay.
12volts on the blu/wht wire when in crank.
the fuel pump follows the yel/grn wire. (12V-on, 0V-off)
the fuel pump follows the grn/yel wire. (0V-on, 12V-off)
fuse #18 under dash is good. (7.5A marked starter signal)
the blk/yel wire has 12V at all times in run or crank
the black wire is ground at all times.
bimmeracer
07-16-2008 06:12 PM
Si-Samuri
29
06-19-2008 05:48 PM
uszcrx
24
09-09-2006 01:05 PM
