Bad alignment or rack need ideas
I got a 96 Civic Ex with power steering, with a 97 GSR motor. The problem is the passenger side, every time I hit a bump the wheel moves as in a bad tie rod, but i replaced inner and outer tie rod. Still doing it, replace the spring and still doing it, there is no play in the tie rod or rack, Any ideas what else to look at??Went over every bolt on the suspension, nothing loose or broken. The wheel does not move at all no play side to side or in and out. the alignment is not really out so i dont think it could be the problem it does pull to the right a little but not alot.
ra64
09-15-2014 06:48 PM
j0keefe21
02-05-2009 04:25 PM
