B7 head on a B8 block
ok the head on my stock 93 cx is messed up so my buddy gave me his old dx head(b7 head) , i've searched but no luck......i need to know what all would i need to change to put that b7 head on my b8 block?
Can i used my cx dizzy?
sparkplugs/wires?
headgasket?
timing belt?
Some one please help i need my car back so i can go back and forth to school/work
sparkplugs/wires?
headgasket?
timing belt?
Re: (bigwally9876)
search "mini me" and there will be alot of threads. im only telling you to search instead of finding a thread for you because
1. i get side tracked
and
2. you will most likely find more info then you would have thought if you search.
im just lazy. it might work though
and
Location: PhantomGrayEH2, CA Where Gay Arnold Rules, USA
Re: (Squallie)
Why search for a mini-me? A B7 head is non-VTEC, the B7 head will drop in directly to your B8 as long as you have the 4 valve pistons. If you only have 2 valve release you can't drop the head unless you change the pistons for 4 valve release pistons. Good Luck and you should see a nice improvement over the B8 head.
