b20b swap too 99 civic
Re: (jdmsi1320)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmsi1320 »</TD></TR><TR><TD CLASS="quote">Be more specific on what you are looking for i have a si with a b20 vtec</TD></TR></TABLE>
Right now I have an si engine and would like to swap it out and put a B20b engine. Other than
the ecu, is there anything else I need to get? will the transmission I have fit with the B20b?
Thanks.
Thanks.
Re: (jdmsi1320)
Also, did you change the whole engine to the b20b? Im looking to swap the whole
longblock in.
longblock in.
the b20b will fit right in. There will be some plugs that will no be used say the vtec solnoid, also there is no pcv valve on the b20b. Also i would get a obd2 to obd 1 conversion harness with a p28 to make sure no c.e.l is on. Also depending on which distributer you use i believe a obd1 wont plug in use a b20/ls obd 2 00-01.
yes the xhaust will fit. same linkages, same clutch and flywheel, in case you buy a auto b20, use the b20 ecu for a 99-00 crv, or obd2-1 conversion harness and a obd 1 crv ecu. I ran a ls p75 on my b20 and it seemed to run good.
yudruln2402
11-03-2004 04:20 PM
sti99civicsi
16
05-07-2004 08:32 AM
