b20 block?
well the ctr is no more and with less than 3k on it and im out of cash. The new option is a b20 block with the ctr head but i don't know a lot about the pros and con's of this swap. Any help would be good thanks!
Re: b20 block? (type-r-heart)
search
b20vtec crvtec this has been done before, it's basically a 'lsvtec' setup but with a 2.0 b20 block |
Re: b20 block? (Mr.RHTuner)
im also hearing that "all" ls/vtec swaps can have a problem with loss of oil pressure
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by type-r-heart »</TD></TR><TR><TD CLASS="quote">im also hearing that "all" ls/vtec swaps can have a problem with loss of oil pressure</TD></TR></TABLE>
to be honest and very blunt...anybody that is having 'oil pressure' problems with a LS/Vtec setup must have half assed it. I have read and seen multiple ls/vtec setups running fine when built properly and tuned right. A friend I know told me this a few years back and I smelt the bs coming from his lips miles away. The LSVtec setup can perform awesome and give great results if built just right and not half assed https://honda-tech.com/forums/images/smilies/emthup.gif now if you ever get a ride in a ls/vtec, imagine using a 2.0 b20 block https://honda-tech.com/forums/images...s/emsmileo.gif https://honda-tech.com/forums/images/smilies/emthup.gif |
Im happy to hear that but after only getting 3k miles out of the last motor im scared of what i may get this time! I hope it will be done right the first time .....this time!...
b20vtec
https://honda-tech.com/zerothread?id=1676914 https://honda-tech.com/zerothread?id=1521697 https://honda-tech.com/zerothread?id=1607086 https://honda-tech.com/zerothread?id=1555476 https://honda-tech.com/zerothread?id=1574667 https://honda-tech.com/zerothread?id=1268832 lsvtec https://honda-tech.com/zerothread?id=1415261 https://honda-tech.com/zerothread?id=1763358 https://honda-tech.com/zerothread?id=1499806 https://honda-tech.com/zerothread?id=1364932 https://honda-tech.com/zerothread?id=1682003 Here are some b20vtec and lsvtec threads from a quick search https://honda-tech.com/forums/images/smilies/emthup.gif |
thanks
do the ls vtec. just make sure you get rod bolts and a new vtec oil pump
Re: b20 block? (fmrprojects)
ARP rods bolts
ARP head studs You know, other stuff too. But those first. |
would the oil pump work out of my b16b?
