b20 almost ready to go, need some info
I am using a 99-00 civic EX harness on my 00 b20z usdm longblock. I already swaped it into my 00 si and im almost ready to go. I have a couple of extra plugs unpluged and would like some info on where they go.
-So far my power steering hose needs a 2 wire round plug and the nearest plug is the knock sensor plug which is 1 wire and also round.
-My IAT is not plugged as well. I'm using a Ls intake manifold and im not sure weather to extend/change the plug to use the Ls IAT or buy a civic IAT and poke a hole into my stock b20 intake elbow.
-I am using a obd1 p75 and was told I dont need the knock sensor or crank angle sensor
need some help please
Modified by S2k Hybrid at 10:34 PM 2/11/2007
up to you on the iat...whichever is fine (i swapped connectors on mine)
p75 does not check for knock or crank angle, no
"power hose needs a 2 wire plug" ?????
Re: (pdiggitydogg)
Hey thanks for responding. When you swapped the IAT plugs, which color wire did you position for the left/right pin on the IAT sensor?
Also I meant *power steering hose* sorry for the typo. The power steering hose running from the rack has a green male plug fitted with 2 pins inserted. I cant seem to figure out which plug i'm supposed use there. Any clue on the wire colors for that plug?
Re: (turb20_vtec)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turb20_vtec »</TD></TR><TR><TD CLASS="quote">Since you are using a obd1 I don't think it'll look for the IAT sensor. Don't quote me on it though.</TD></TR></TABLE>
It WILL look for the IAT. I just extend the wires and run an obd1 plug to the IAT on the intake mani.
Re: b20 almost ready to go, need some info (ekjay)
I definitely dont want my motor to have problems, can you be more specific? I'm trying to picture which 2 sensors you're talking about but I dont have a clue.
Also, anyone know which plug to extend or swap out for my power steering hose.
Re: b20 almost ready to go, need some info (smileycvc)
By swapping the TPS and MAP sensor, do you guys mean to relocate? I wasnt aware the 2 sensors needed to be relocated
I have a usdm 2000 b20z motor and I havent started it up since I purchased it from the yard.
*Also, I believe the swap is a obd2b*
*Also, I'm using a obd1 Ls intake manifold*
Im going to try starting it up tomorrow, im feeling a little lazy cause of the cold weather
I still need to figure out the wiring for the IAT and the power steering hose plug
holy crap so many peple not knowing what theyre talking about....
I'll get you which pin is which color for the iat later today.
Same for the power steering connector
ok, on the iat connector, the bottom pin is yellow, top is black
on the power steering, the wires are green and black
(sorry, i dont remember which is which, its freezing out now and snowing like crazy)
Re: (pdiggitydogg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pdiggitydogg »</TD></TR><TR><TD CLASS="quote">ok, on the iat connector, the bottom pin is yellow, top is black
(sorry, i dont remember which is which, its freezing out now and snowing like crazy)</TD></TR></TABLE>
Thanks for the help
I'll figure out the positioning of the PS wires through trail an error. If by any chance the positioning is incorrect, should I expect a check engine light or would the power steering feel heavy?
Thanks for the help
