B18C1 swap into 92 hath minor problems
i have been using this site for about 5 months to get ready to do this swap and ran into complications on my install...
1) the power steering pump for the hatch does not fit the 94 gsr motor do i need the gsr pump or is there anouther solution.
2) the coolant lines - there is one long one that comes off the thermostat housing does it hook into the heater core where the flaper door is? and the other one coming back out from the heater core does it hook to the metal cross over tube that goes back to the block on the drivers side?
any help would be great after i figure this out i will be tackaling the ecu wiring for the solenoid so any help on that would be great too thanx
Re: B18C1 swap into 92 hath minor problems
yeah gsr power steering, the heater hose issues is hard to answer without pics, are you talking about the one that hooks up to the throttle body? that ones kinda long.
