B18c turbo set up build.
Hey guys, im getting ready to do a build my bottom end for boost. Tell me what you guys think.
I have a b18c in my eg.
81mm Cp piston(9.8:1)
Eagle H beam rods(cuz there cheap) Or maybe manely h beam
ACL main bearings
Cometic head gasket 81mm(what thickness do you guys rec for this turbo set up)
and the head ima leave stock right now prob going to do a b16 head
ACL main bearings
Re: B18c turbo set up build.
i was thinkin bout 9:1 but im not gonna be boosted 4 a while so i want lil power lol. do u guys think 9:1 would be better than 9.8:1 for this set up? OEM Head gasket or OEM spec?
I'm not Rick!
dont bother getting a b16 head. b18c head is better for boost anyways. (but you will get some arguements about this) especialy if plan on down the road goin up to 9k rpm. but if you end up just porting it out it wouldnt matter what head. get wiseco pistons 8.8 comp. get a gooood turbo
^^ damn rick you go from thread to thread posting you bullshit. You dont want 8:8 ration because like the OP then you wont have any power on the lower RPMs.
I'm not Rick!
i noticed you argue alot in your threads..is there any reason to argue? arent you the one that said this...?
"dont just post **** to bash others or to just have a post. You ever heard of a vitara build?
Yes my friend there is a reason to argue and that is because people like yourself that dont know what their talking about post there BS comments that miss leads others.
Yes my friend there is a reason to argue and that is because people like yourself that dont know what their talking about post there BS comments that miss leads others. There's a reason why you have 700+ post within 3 months and thats simple because you post to just have a post count.
As stated above. Post this question in the forced induction section and you'll get much better responses from people who actively produce/run FI vehicles.
Y oem over cometic? a buddy of mine has that in his fully built lsV turbo coupe and its fine. few ppl told me 2 get OEM head gasket 2. but y? and what kind of turbo andhow much?
I'm not Rick!
I'm done with you we'll talk through PM's instead of taking up space in this thread
^^To answer your question the oem headgasket is actually very well made and can handle qute a bit of power. My friend mike in my friends is planning on make 600whp with his and its been done numerous times. I do have an after market one that is thicker so it'll lower my compression.
Now that you mention it, it probably won't be a bad idea. I myself have a inline pro 2mm headgasket. One word of advice dont by a hook off or a cheap one.
I'm not Rick!
i have a turbo gsr build
oem head gasket.
i ported and polished the head(gsr head)
Supertech dual valve springs and titanium retainers
Crane stg1 cams
Stock ignition
1000cc injectors
Tuning on crome
Stock tranny.
Turbonetics turbo
Made close to 380hp on 10lbs
Stock oem HG from Honda will handle quite a bit of boost like 20lbs. Iv haven’t been up that high yet. But from talking to people here localy doing 10s 11s they all use oem HG.
oem head gasket.
Crane stg1 cams
Stock ignition
1000cc injectors
Tuning on crome
Stock tranny.
Turbonetics turbo
it's a garrett t3t04e turbo, .60 intake, 63exhaust. shaft play =none
was making about 320wheel on 10psi, and then the motor dropped a valve, ****ed up #3 piston, oil squirted everywhere, bye bye motor lol
stock lsvtec btw
stock lsvtec btw
WTF guys this isn't post your setup thread.
OP like I said i would recommend a thicker headgasket just to lower the compression alittle.
