b18b1 surging idle
Old Mar 28, 2012 | 10:23 PM
jrhcivak's Avatar
Default b18b1 surging idle
i bought my 93 eg with a b18b1. the guy i bought it from disconnected the tps cus it was going bad and causing it to chug under low throttle input.
soo i bought a new tps. its still throwing a cel but i havent got it checked to see what it is.
before i put the new tps on, the idle was high. around 1800 rpm. now the idle is around that when cold, but drops to like 900 when warmed up.
after driving and coming to a stop, the idle will be around 1300, then drop to 900 and surge between that.
if im driving and push the clutch in, the idle will still surge like that as well.
im assuming some other sensor is bad. but im clueless as to what one it might be. this is my first honda so im new to this ****.
anyone have any thoughts on what it might be? any input is appreciated.
thanks
Old Mar 28, 2012 | 11:29 PM
jbpnoman's Avatar
Default Re: b18b1 surging idle
Pull the CEL. That'll probably tell you exactly what it is.
Old Mar 28, 2012 | 11:37 PM
Dc4LsTeG's Avatar
EK9
X2 could've pulled the cel quicker then it took to write that. Most likely your iacv. Check cel reset ecu recheck cel
Old Mar 29, 2012 | 07:03 AM
typerturbo29's Avatar
IACV unplug it and see if surging stops
Old Mar 29, 2012 | 07:42 AM
grumblemarc's Avatar
The Grumpiest
You installed a new TPS. Did you calibrate it?
Old Mar 29, 2012 | 07:47 AM
MRGRIM's Avatar
R.I.P. Mark
as above calibrate the tps "its not just a bolt on "
and clean the IACV
Old Mar 29, 2012 | 08:33 AM
mcneil's Avatar
Since you seem a little inexperienced, to calibrate the tps, you need to check voltage of the red wire for the tps. With the key on, it should read .5 volts in closed throttle conditions, and 4.5volts in wot.
Old Mar 29, 2012 | 08:48 AM
jdmcx's Avatar
and clean the IACV
IACV
bypassed mine.
pfsmith99
Oct 14, 2012 09:02 AM
dllnzek
Aug 15, 2012 10:42 PM
92bseries
Dec 7, 2011 12:59 PM
Baron55
Acura TSX
Jul 8, 2009 12:22 PM
mafay2
Jul 13, 2005 11:52 AM
