b18b into 95 sol HELP PLZ...!
i have a 95 del sol s 1.5 and im curretly building a b18b. wit just the basics such as rods pistons, cams camshft and thats bout it for boost and this is my first project and swap . i know i need axals mounts but will my ecu still work out of the 1.5 since non-vtec , also will the wiring harness plug and play.. i need to know pretty much what i will need for the b18b swap into 95 eg1 1.5 non-vtec if u can help plz ur not wasting ur time it would be a great help thanks!
Re: b18b into 95 sol HELP PLZ...! (95dsol)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95dsol »</TD></TR><TR><TD CLASS="quote">i have a 95 del sol s 1.5 and im curretly building a b18b. wit just the basics such as rods pistons, cams camshft and thats bout it for boost and this is my first project and swap . i know i need axals mounts but will my ecu still work out of the 1.5 since non-vtec , also will the wiring harness plug and play.. i need to know pretty much what i will need for the b18b swap into 95 eg1 1.5 non-vtec if u can help plz ur not wasting ur time it would be a great help thanks! </TD></TR></TABLE>
1)You need a 92-93 or 94-95 Integra ECU to run a b18b properly. Or you can get your chipped but I'd recomend running the factory computer.
2)Your factory OBD-1 Wiring harness will work fine...just get a obd-1 b18b
rest of your info search for it
90civichb
17
07-07-2004 08:56 AM
