B16a3 swap to a Sleeved B16
i am swapping out my b16a3 in my 94 delsolVTEC for a sleeved b16a block...it comes with a crank and im going to upgrade bearings, rods, and pistons 9:1. Will everything else from my b16a3 engine compartment bolt up to this B16A block, (example ecu, head, wiring harness, oil pump, water pump, alternator, knock sensor, hydro tranny, clutch , flywheel , every sensor and every part you can think of)???? the stamp on the block says B16A 1213263
please make a list for me thanks so much
Re: B16a3 swap to a Sleeved B16 (94delsol)
Yeah dude, a B16 block is a B16 block, if you take all your parts from one and transfer them over, then you're good.
