B16a2 engine throws map sensor code 3,help
Old Mar 25, 2008 | 01:40 AM
baulum's Avatar
Default B16a2 engine throws map sensor code 3,help
I've honda equipped with a honda b16a2 engine.The engine is now behaving weirdly and throwing map sensor code 3.I replace the sensor and it still acts as before.Can anyone help me out to rectify this problem? Thanks in advance.
Old Mar 25, 2008 | 10:12 PM
baulum's Avatar
Anyone????
Old Mar 26, 2008 | 09:30 PM
baulum's Avatar
where are the tech?
Old Mar 26, 2008 | 09:51 PM
aznej2's Avatar
Default Re: (baulum)
what car is it in? did u do any re wiring? and after u swapped the sensor did u reset the ecu?
Old Mar 27, 2008 | 11:41 PM
baulum's Avatar
No i have not checked the wiring yet.My car is at the mechanic right now and will check it asap.And it also throws a cel code 7,i.e TP sensor.What could be wrong with it?
Old Mar 27, 2008 | 11:47 PM
baulum's Avatar
The engine is in a 1996 civic sedan.It comes from an eg6 A/T 92-95 which i converted to M/T.I ignore what wiring they used in my 1996 civic(whether an b16 A/T wiring or b16 M/T) as i undergo several problems with ignition,i've a distributor problem.
Old Mar 28, 2008 | 12:09 AM
SirRevvs's Avatar
So it throws a 7 and a 3 hmmmmm.... I'd bet you got your tps and map sensor plugs backwards. They're interchangeable.
Old Mar 28, 2008 | 12:13 AM
fmrprojects's Avatar
Default Re: (SirRevvs)
sounds like you have the plugs switched. car will run but it wont rev past 1500 prms
Old Mar 28, 2008 | 10:59 PM
baulum's Avatar
****,concerning the tps cel,it is no more now.I come to know that my mechanic had unplugged it with engine on and then reconnected it.So it has been saved when i was checking the map sensor cel.Forget about the tps now.I've three problems now:the map sensor issue,engine sputter and my sparks are covered with oil.
I've recently put a pair of big cams and the map sensor prob has been arising before i put the cams.Its worse now.don't know where to start.
JasonST
Apr 26, 2006 07:36 AM
lv6l
Nov 10, 2005 02:19 PM
ahondaguy
Jan 14, 2005 09:26 PM
chrysler kid
Sep 28, 2004 07:24 PM
1BadCvC
Sep 13, 2003 07:01 AM
