B16a1 in a 95 Civic!!!
New User
I have a B16a1 in my Honda Civic 1995
List:
b16a1
SI 2000 tranny
1993 GSR axles
1995 GSR shifter
PR3 JDM Ecu 8,700 rpm
Bronze clutch
14.72 @ 95.6 mph
Stock tires at 15 psi
iceman
all interior in
spare in
all stock!
New mods i do soon!!!
USDM Integra Type R pistons.
mill .030" head
CTR intake Cam
[IMG][/IMG] [IMG][/IMG] [IMG][/IMG] [IMG][/IMG] [IMG][/IMG] [IMG][/IMG] [IMG][/IMG] [IMG][/IMG] [IMG][/IMG] [IMG][/IMG] [IMG][/IMG] [IMG][/IMG]
List:
b16a1
SI 2000 tranny
1993 GSR axles
1995 GSR shifter
Bronze clutch
14.72 @ 95.6 mph
iceman
all interior in
spare in
all stock!
mill .030" head
CTR intake Cam
Re: B16a1 in a 95 Civic!!! (CoamoB16a)
Also, is that a legal setup? I mean, the B16A1 was the first gen correct? I was under the impression that you could only swap in the same year or newer engine as your cars model year. I am interested in this info because the 1st gen B16's are so cheap. Thanks.
New User
Why in the world did you drop your PSI down to 15lbs on stock tires...for one the side walls are being destroyed, second they are not wrinkle wall tires so they won't launch you like a slick will, and for the LITTLE and I do mean little traction you might gain in your 60ft time you will lose for the rest of the quarter mile because you have now put so much rolling resistance on those tires. But you still pulled a decent time, I just can't understand why you treated street tires like slicks.
New User
Re: B16a1 in a 95 Civic!!! (Inaniac)
Yea, CTR pistons are a good choice and will run on pump gas , no prob....May want to get into the cam & poss. headwork too!!!
hrm...
Am I the only one who finds a 14.7 run on a bone stock B16A1 motor, with a blistering 160hp & 111ft/lbs...in an EJ1 with full interior and stock tires...a bit on the iffy side? How is that possible? How is it, that Steph Papadakis only got a 14.9 from a B16A built by JUN, with high compression pistons, cams, valvetrain, JUN ECU, all bolt ons, drag radials, no interior, race gas, limited slip differential, etc...and you get 14.7 from a torqueless stock motor in a heavier car? I don't know, I just have a hard time buying it.
1 Post
Re: hrm... (MatT3T4)
Papadakis actually pulled a low 14. Something like 14.15.
I have a friend with a first gen b16 w/ bolt ons in a 96 sedan running 14.7s. Doesn't make sense to me, but he does it.
Re: hrm... (CoamoB16a)
88-91 Civic/CRX B16A1: 160hp
90-93 Integra XSi B16A1: 160hp
92+ Civics had the 170hp B16A...so you either have a second gen and up B16A, or 160hp...take your pick.
Regardless, that means a Civic with a stock B16A can beat an ITR?
. WAAS_SAPPENING
15
06-12-2006 06:51 PM
bfong13
20
11-28-2004 04:32 PM
