B16a won't start after warmed up
I recently bought a 4 door eg with a b16a in it. The only problem I've had is that after it gets warmed up and then shut off, it won't start until it cools down. But if you try to start it right after you shut it off, it starts right up. The motor is a b16a sir II
Re: B16a won't start after warmed up
If the fuel pump won't prime and the CEL stays on steady when the engine won't start, then resolder the main relay and clean/tighten the G101 ground on the thermostat housing.
If none of this works also check to see if the injectors are pulsing once it starts doing this. My injectors had problems but only after the car was warm. Still trying to figure it out but it's looking like its the ecu. Runs perfect until the exact conditions you are specifying here. Mine starts but has a miss.
One other thing is when it gets warmed up it idles really shitty. It pulses from 1100-1500. It didn't do this at first, but definitely does it now. Lol
Alright, I put a new temp sensor in, resoldered the fuel relay and took the throttle body off and cleaned that..cleaning the IACV as well when I get a chance. It stopped doing the no start for a few days, and now started again. It tries to start when it's almost warmed up, but won't fully turn on until its completely cooled off. When you put in gear and start to go it makes a screeching sound for about 2 seconds. It only does that after the no start, not on cold start.
the screeching sounds like an unrelated belt slipping issue. did you clean your fuel injectors? it's easy to do. I removed them and used a big syringe with lacquer thinner and a battery to supply 12v. be careful though because that lacquer thinner is flammable and you are creating a spark.
This a old thread..
skylinerb26dett
02-04-2013 08:50 AM
crujones
05-02-2002 07:48 PM
