B16A into a 97 d16 hatch
what mounting differences will be encountered when installing a b16a in a 97 civic hatch back with its D16 wiring and mounts? which wiring harness and mounts can i get that will suffice , it has a y2k 1 trans and hydraulic clutch, and if it matters the motor doesn't have any other intake manifold # like A1 A2 A3 A6 etc, will this have an affect on the installation? [IMG][/IMG]
Re: B16A into a 97 d16 hatch (matt_tuck)
Use your stock driverside timing belt mount, and your stock top tranny mount. You can reuse the rear rubber mount, but you will need to get a new "L" shaped bracket from a 99-00 SI. If you want to retain your AC you will also need to get a Delsol VTEC, AC mount. You will also need the front tranny mount from a B series tranny.
-Ace
-Ace
Re: B16A into a 97 d16 hatch (Aceman64)
http://www.hybridgarage.com/te....html
Might be able to find some more information there.
http://www.hybridgarage.com/tech/6gtech/index.html
There is a picture of the "L" bracket I was referring to on that page.
-Ace
-Ace
if you got pictures it would be best. but you can use your stock harness, two top mounts and you'll need linkage, front tranny and a/c bracket unless you got a/c and want to retain it.
E-mac
07-28-2012 03:42 PM
civicmobileone
04-25-2007 12:38 PM
