B16a head gasket job
The search wasn't functioning. Does anyone know a good writeup? I'm sure a lot of it is commonsense, I'm pretty good with working on cars, but I want to know if there is anything not obvious I should look out for. I think the motor got a little hot, the needle started to creep towards the red, but I shut it off when that happened, then like a week later it started to miss a lot and the next day it got really bad. I pulled the plugs and cylinder 4 was all wet. Is it possible that getting the motor a little hot could have caused the motor to warp enough to get the gasket to go bad? When I kicked the cap off and coolant sprayed everywhere, when I usually take it off when it's hot, it doesn't even bubble. How do thinner ones work? Thanks
Re: B16a head gasket job (ED9man)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ED9man »</TD></TR><TR><TD CLASS="quote">The search wasn't functioning. Does anyone know a good writeup? I'm sure a lot of it is commonsense, I'm pretty good with working on cars, but I want to know if there is anything not obvious I should look out for. I think the motor got a little hot, the needle started to creep towards the red, but I shut it off when that happened, then like a week later it started to miss a lot and the next day it got really bad. I pulled the plugs and cylinder 4 was all wet. Is it possible that getting the motor a little hot could have caused the motor to warp enough to get the gasket to go bad? When I kicked the cap off and coolant sprayed everywhere, when I usually take it off when it's hot, it doesn't even bubble. How do thinner ones work? Thanks</TD></TR></TABLE>
Are you talking about the cap that on most cars usually says "don't remove while hot" (or something along those lines)
Re: B16a head gasket job (Syndacate)
haynes manual... i did my head gasket all by myself with one... but !!cya!! do it in an organized fashion or you may end up with 11 headstuds or something
vbcrixmanz
11-28-2007 01:57 PM
