Which B16A is this?
Which B16A is this?
Im trying to determine which version of the B16A I have. I know its not an A2 or an A3, but trying to confirm whether or not its a OBD1 or OBD0.
Re: Which B16A is this?
OBD1. Radiator fan switch is on the thermostat housing not back of block. 92 head casting means 92-94 motor. I'd say it has been pieced together though, the valve cover looks to be from a GSR
And is the intake OBD1 or OBD0? The only reason I ask is because the motor came with an throttle body that was considered OBD0 and I guess my question next will be, what throttle bodies will fit perfectly onto this motor?
Crazy Honda Guy
It's a 2nd gen intake manifold for sure, only p30's were. OBD0 were stamped pr3. Any 92-00 b series throttle should work just fine on that manifold (94+ gsr will need a reverse throttle rotor)
i have a 1999 honda civic si with a B16A (stock) the vins on motor match the vins on car . Which is jdm. so its not just a 1992. its obd1 and they are pretty snappy. if there isnt a number at the end of the stamp on block then its jdm. these motors are highly popular and very common swaps.
Crazy Honda Guy
^^ The poster took a picture of the cylinder head stampings......they show his engine was made in 1992. That's how we know when it was made and that it was originally an obdI designation
b16a2 is usdm that was stock engine for 99-00 civic si. b16a is from japan but fits usdm emission standards. SIR is straight from japan with no corrections, those are kind of hard to come by. Your engine is jdm b16a and im pretty sure its OBD1
His engine is not usdm its jdm and just because its jdm doesnt mean its SIR.
the pressure switch on the vtec solenoid shows obd1
I dont know the history of the engine and its mountings sad to say. Previous owner didnt have much to say on it in that regard. Currently Im looking to get a trans and a starter so I can test its compression, before I move any further into the project.
I appreciate all the info provided here. THough not sure what the GSR reverse throttle linkage is. Im not looking for extreme performance, so would a 94/95 accord throttle body work as well?
Seagull Management
JDM B16As do not comply with US emissions (not without some parts swapping anyway) The JDM B16A came in the SiR, and no they really aren't that hard to come by
Thats what im saying..JDM b16a's dont comply with US emissions which in turn when they come from japan they are basically changed back to a b16a2..SIR is just straight from japan without changing the standards..
Crazy Honda Guy
What???? Sorry, what do you think is being changed on the engine?
