b16 swap into an eg. Need help with mounts
Old 06-20-2004, 09:38 PM
civic_freak's Avatar
Default b16 swap into an eg. Need help with mounts
My friend and I are swapping a b16 into his eg hatch. We are using the HAsport motor mounts. I was under the impression that all he would need besides the mounts, would be the rear tranny mount bracket from a 99-00 si. When we went to put the motor in yesterday, we got the driver's side, and passenger's side mounts in, but the rear mount won't line up with the si mount bracket. The hole on the bracket sits about an inch forward of the hole in the mount, and I don't think there is a way to get a whole inch of play out of those beefy mounts. ANY help would be greatly appreciated. Thanks in advance guys.
Brad
Old 06-20-2004, 10:04 PM
TSPeed Factory
AzntaggeR's Avatar
Default Re: b16 swap into an eg. Need help with mounts (civic_freak)
you need a rear motor mount from an integra, such as an LS or GSR.
Old 06-21-2004, 07:01 PM
odagenr's Avatar
Default Re: b16 swap into an eg. Need help with mounts (AzntaggeR)
did my swap in early january... the rear mount we used was the stock rear honda motor mount from the b16 del sol (95 or so)
Old 06-21-2004, 07:05 PM
Moderator
chad's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AzntaggeR &raquo;</TD></TR><TR><TD CLASS="quote">you need a rear motor mount from an integra, such as an LS or GSR.</TD></TR></TABLE>
yes....
99-00 SI will NOT work in an eg....in an EK yes...but no go on eg....
Old 06-21-2004, 09:41 PM
Default Re: b16 swap into an eg. Need help with mounts (chad)
Thanks for the replies. Is there any particular year and model I should ask for at the dealer? We already got the 99-00 si mount bracket, and I don't want to end up with yet another unusable bracket. Will any year teg that came with a b18 work? Thanks.
Brad
Old 06-21-2004, 09:46 PM
TSPeed Factory
AzntaggeR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civic_freak &raquo;</TD></TR><TR><TD CLASS="quote">Thanks for the replies. Is there any particular year and model I should ask for at the dealer? We already got the 99-00 si mount bracket, and I don't want to end up with yet another unusable bracket. Will any year teg that came with a b18 work? Thanks.
Brad</TD></TR></TABLE>
any 94-01 integra rear mount bracket will work for sure. i think 90-93 integra rear mount brackets will work too, but i'm not 100% sure. since you have a B16 rear motor mount bracket try trading it with someone who has an integra one. save you some money.
Old 06-22-2004, 12:53 AM
hybridhondasquad's Avatar
the driver and passager from ur old motor will work the only thing u need is the rear braket from a ls or gsr. if u run ac they u need that one to but if not ur good
Old 06-22-2004, 09:47 AM
crzymine03's Avatar
you should use ur gsr or ls mount they work perfect everything should line up
Old 06-22-2004, 10:09 AM
93Civac's Avatar
Default Re: (crzymine03)
Old 06-22-2004, 02:55 PM
SoCalB16a2's Avatar
just use your stock civic tranny mounts..you dont need aftermarket mounts for the rest. all its gonna do is make your car shake. gsr mounts are fine.
Old 06-22-2004, 03:48 PM
tallblondkid's Avatar
Default Re: b16 swap into an eg. Need help with mounts (SoCalB16a2)
bump -- i would also like to know about this
do u need a new a/c mount and right front mount or can u use the the stock civic mounts
Old 06-22-2004, 04:26 PM
Moderator
chad's Avatar
Default Re: b16 swap into an eg. Need help with mounts (tallblondkid)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tallblondkid &raquo;</TD></TR><TR><TD CLASS="quote">bump -- i would also like to know about this
do u need a new a/c mount and right front mount or can u use the the stock civic mounts</TD></TR></TABLE>
you need INTEGRA FRONT BRACKETS......and civic tq mounts that attach to the frame via 2 14 mm bolts....
civic BRACKETS WILL NOT WORK ON FRONT OF ENGINE.....
Old 07-06-2004, 06:41 PM
XzzYzzX's Avatar
Sorry to jack your thread but if i am puttin a b16 sir 2 i would use the stock jdm rear mount, side engine mount, right front mount and the stock tranny mount from the dx. Didnt' want to start another thread..
418whpturboD
01-03-2008 11:45 AM
90crxdxb16
09-08-2006 11:12 AM
92CiviC4dr
03-02-2006 08:04 AM
RICE POLICE SIP
01-07-2005 03:09 PM
NCHATCH
05-26-2003 02:23 PM
Quick Reply: b16 swap into an eg. Need help with mounts
