B16 smoke
B16 smoke
In my b16 hatch if I roll down a hill in gear just letting the compression hold me back then push the gas after a few seconds I get large clouds of blue(oil) smoke. Any Ideas where I'm leaking?
Re: B16 smoke (binxers)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by binxers »</TD></TR><TR><TD CLASS="quote">In my b16 hatch if I roll down a hill in gear just letting the compression hold me back then push the gas after a few seconds I get large clouds of blue(oil) smoke. Any Ideas where I'm leaking?</TD></TR></TABLE>
The tech forum might provide more responses.
All Motor Mentor
1 Post
Re: (x00gsr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by x00gsr »</TD></TR><TR><TD CLASS="quote">SEAFOAM the car!! </TD></TR></TABLE>
lol....well I'd do a compression test at the very least, or ideally a leak down test to see what's going on in there...it's either a ring or valve seal issue.
All Motor Mentor
1 Post
Re: (x00gsr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by x00gsr »</TD></TR><TR><TD CLASS="quote">Im serious, seafoam the car. I have a b16 and it use to puff out black smoke. Ever since i seafoamed it. Not a puff since.</TD></TR></TABLE>
yep, but notice he said BLUE smoke, not black..
Re: (00Red_SiR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 00Red_SiR »</TD></TR><TR><TD CLASS="quote">
lol....well I'd do a compression test at the very least, or ideally a leak down test to see what's going on in there...it's either a ring or valve seal issue.</TD></TR></TABLE>
Compression test showed 217-220 psi on all 4 cylinders on Saturday, so I'm not sure what else it could be if it's not a valve seal issue.
All Motor Mentor
1 Post
Re: (All-MotorSports)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by All-MotorSports »</TD></TR><TR><TD CLASS="quote">
Compression test showed 217-220 psi on all 4 cylinders on Saturday, so I'm not sure what else it could be if it's not a valve seal issue.</TD></TR></TABLE>
Does the car puff blue smoke when starting it up first thing in the morning or when it's been sitting for a while? That would be an indication of valve seals needing replacement. Other than that, has the engine been rebuilt before?
Re: (00Red_SiR)
Does the car puff blue smoke when starting it up first thing in the morning or when it's been sitting for a while? That would be an indication of valve seals needing replacement. Other than that, has the engine been rebuilt before? </TD></TR></TABLE>
I'm not sure. It's not my car, so all I know for sure is what the compression #'s were this weekend.
No, the engine has not been rebuilt. It's a stock B16A2 block mated to a B18C1 head w/ a CTR intake cam.
ha ha thanks chris for doing all my replies for me, i've been out of town for a while! the car smokes only after compressing down hill, thats it. its blue smoke not black ( oil not gas ). It doesn't smoke at start-up and my oil levels are not changing much. I'm thinking (along with board of advisers) valve guides, i just wonder if anyone has seen similar instances?
Re: (binxers)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by binxers »</TD></TR><TR><TD CLASS="quote">ha ha thanks chris for doing all my replies for me, i've been out of town for a while! the car smokes only after compressing down hill, thats it. its blue smoke not black ( oil not gas ). It doesn't smoke at start-up and my oil levels are not changing much. I'm thinking (along with board of advisers) valve guides, i just wonder if anyone has seen similar instances?</TD></TR></TABLE>
Sorry about that. You weren't replying, so I figured I'd jump in there for you.
jordan_civic
02-12-2008 01:38 PM
