B16 sir2 Motor Swap what PS Pump and hardware to use in a 99 civic ex---HELP!!!
Ok I got the motor in the car over the weekend and it is all wired up with the help of some soldering, heat shrink tubing, and electrical tape. I have two parts to the motor left to hook up the AC Compressor which I now know I can use the dseries compressor with a del sol or crv ac bracket. Now comes the power steering. What do I need for the easiest solution. The motor is a jdm b16 gen2 obd1 motor. I have read that a 92-93 ps pump and bracket will bolt up and I can use the high pressure ps line already on the car. Is there another way. The b16 ps pump and bracket came with the b16 swap already attached with the lines cut. Can I use a different high pressure line instead and keep the ps pump and bracket that came with the motor???? Or can I use my ps pump that came off of my d16 with a different bracket?
Re: B16 sir2 Motor Swap what PS Pump and hardware to use in a 99 civic ex---HELP!!! (DetainedCivic)
i did the same swap. just use the same line, maybe from a salvage yard. as for the pump, it looked the same as the d-series, so maybe that'll work. the line bolts right to it, not sure about the bracket, don't have the motor anymore.
Re: B16 sir2 Motor Swap what PS Pump and hardware to use in a 99 civic ex---HELP!!! (philosofy1)
Use the same line, which line, the line that will fit the b16 pump???
I figured someone on this forum knew what they were talking about
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DetainedCivic »</TD></TR><TR><TD CLASS="quote">Use the same line, which line, the line that will fit the b16 pump???</TD></TR></TABLE>
the pump line from the b16 and the civic are the same.
you can use the line from any 92-95 civic, but you MUST use a b16 (p30) ps pump and brackets
Re: B16 sir2 Motor Swap what PS Pump and hardware to use in a 99 civic ex---HELP!!! (deckster333)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by deckster333 »</TD></TR><TR><TD CLASS="quote">you can use the line from any 92-95 civic, but you MUST use a b16 (p30) ps pump and brackets</TD></TR></TABLE>
i was wondering the same. good to know since the b16 del sols are P30.
Cool I will try the 92-95 ps line here soon. I have a friend with one laying around so I will take the b16 pump over to his house and see if it bolts up. I will let you know.
Here is what I learned. I used the d16 ps pump and mounted it to the b16 block. HAd to use a longer bolt at the top. I also used the b16 pulley on the d16 pump. Tightened my belt and it looked good.
DetainedCivic
07-20-2006 11:51 AM
