b16 Question
Old 04-07-2008, 09:22 PM
Coolero's Avatar
Default b16 Question
popped my b16 in my 2000 si and now i got another one form my buddy, but he has a 94 del sol b16 can i slap that bitch in or would i need anything else ????
Old 04-07-2008, 09:24 PM
Frickr's Avatar
Default Re: b16 Question (Coolero)
i think you'll have to swap oil pumps, as the OBDII uses a crank sensor thats located in the pump.
Old 04-07-2008, 09:26 PM
daniel_ek's Avatar
everything should be exactly the same thing just use ur same wiring off ur old one
Old 04-07-2008, 09:27 PM
Cool Cool Island Breezes. BOY-EE
B serious's Avatar
Default Re: b16 Question (Frickr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Frickr &raquo;</TD></TR><TR><TD CLASS="quote">i think you'll have to swap oil pumps, as the OBDII uses a crank sensor thats located in the pump.</TD></TR></TABLE>
yes. Besides that, swap injectors, and a few intake manifold plugs (or just swap over the OBD2 manfold and sensors). The rest is pretty much the same. The distributor will need a wiring mod or a wiring harness. It's just a 2 wire mod. The OBD1 distibutors came with a seperate little 2 prong harness for the power wire and tach wire. The OBD2 cars had it built into the same connector. Snip, crimp on quick disconnects, tape, done.
The alternator plug is different. So use your OBD2 alternator.
Old 04-07-2008, 09:39 PM
Coolero's Avatar
Default Re: b16 Question (B serious)
what about ECU?
Old 04-07-2008, 09:41 PM
B serious's Avatar
use your stock 99-00 Si ECU.
NZDelsoldude
09-22-2014 08:35 AM
Brettw
04-29-2013 04:47 PM
duneracer69
05-12-2008 06:24 PM
joethejoeman
10-17-2006 04:30 PM
SpeedMonkeyRacing
05-04-2004 04:31 PM
Quick Reply: b16 Question
