b16 into eg6???
Old 11-30-2003, 06:52 PM
CaptinMcnut's Avatar
Default b16 into eg6???
is swapin a b16 into an eg6 hatch fairly hard its a full swap axles tranny ecu all that if i had all the tools and i have mechinal sense and so do alot of my friends would it be fairly hard ?????? waring is what i worry about help please!!!!!!
Old 11-30-2003, 07:02 PM
JV
Who?
JV's Avatar
Default Re: b16 into eg6??? (Darren 92 civic)
Considering an EG6 is already equipped with the B16... No.
Swapping a B16 into an EH is not that hard either.
Wiring is fairly simple:
It would also help to know the year and trim level.
Old 11-30-2003, 07:03 PM
huh?? ok well its a 92 hatch si model i thought that was an eg6?? oh well thanks for clearin that up
Old 11-30-2003, 07:14 PM
JV
Who?
JV's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Darren 92 civic &raquo;</TD></TR><TR><TD CLASS="quote">huh?? ok well its a 92 hatch si model i thought that was an eg6?? oh well thanks for clearin that up
It's actually an EH3 (USDM 92-95 Civic Si).
If you are gonna use the wiring harness from the z6, you will only need to worry about wiring up the knock sensor. Everything else should be plug and play...
Old 11-30-2003, 07:37 PM
HATCHingMN's Avatar
Default Re: b16 into eg6??? (JV)
Whats better B16a1 or B16a2?? consider the (A1) generation one cost less and making 160 hp would it make a better buy??
Old 11-30-2003, 07:52 PM
salbaje's Avatar
Default Re: b16 into eg6??? (HATCHingMN)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HATCHingMN &raquo;</TD></TR><TR><TD CLASS="quote">Whats better B16a1 or B16a2?? consider the (A1) generation one cost less and making 160 hp would it make a better buy??</TD></TR></TABLE>
it would be a better buy but you will need to change alt, injectors,dist to even make it an obd1 motor.
Old 11-30-2003, 07:54 PM
jeremyEG's Avatar
Default Re: b16 into eg6??? (salbaje)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by salbaje &raquo;</TD></TR><TR><TD CLASS="quote">
it would be a better buy but you will need to change alt, injectors,dist to even make it an obd1 motor. </TD></TR></TABLE>
not to even mention that the a1 has a cable tranny and you need a hydro for 92+
Old 11-30-2003, 08:10 PM
HATCHingMN's Avatar
Default Re: b16 into eg6??? (jeremyEG)
so A2 is much easier to swap??, less work right??
Old 11-30-2003, 08:23 PM
TorganFM's Avatar
Get a B18B. Less HP but more torque. HP sells cars, Torque wins races.
Old 11-30-2003, 08:35 PM
HATCHingMN's Avatar
Default Re: b16 into eg6??? (TorganFM)
I am thinking about GSR B18c
Old 11-30-2003, 09:25 PM
TYspeK EH2's Avatar
i love that saying...
Old 11-30-2003, 09:29 PM
JDMlyfestyle's Avatar
Dont need to wire up a knock sensor if u get a chipped P28. Id go with the A2 much easier swap to do.
Old 11-30-2003, 09:34 PM
G-money's Avatar
Default Re: (JDMlifestyle)
i'd go A2 ..a lot easier... everythig is obd-1 already all you really have to do is plug everything in and run a knock sensor wire or a chipeed p-28 ecu...and thats it basically like putting a sohc in it...it's that easy
Old 11-30-2003, 10:22 PM
whoDAT's Avatar
Default Re: (All MTR TODA HATCH)
attn: JV ...for the gsr/ dual butterfly hookup, all you do is swap A17 and A20 correct? tia
*edit* car is a 93 del sol si.
Old 11-30-2003, 10:24 PM
Filliam H. Muffman's Avatar
Default Re: (whoDAT)
a b16 swap is way too complicated.
just be simple and settle for the k20 swap
Old 12-01-2003, 01:59 AM
Default Re: (JUN EK9)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JUN EK9 &raquo;</TD></TR><TR><TD CLASS="quote">a b16 swap is way too complicated.
just be simple and settle for the k20 swap </TD></TR></TABLE>
haha
Winlight
02-11-2007 08:58 PM
chevee396
03-16-2003 07:06 PM
Quick Reply: b16 into eg6???
