b16 or b17
b16 or b17
I just got my hatch and looking to get a motor, which is better b16 or b17? I understand the b17 has a little more horsepower and torque.
Re: (MichaelJComputer)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MichaelJComputer »</TD></TR><TR><TD CLASS="quote">b18.
Iif you MUST decide between a b16 and b17 I'd say go with the 16 as parts are difficult to find for a 17.</TD></TR></TABLE>
exactly what he said...
orrrrrr go my route and SOHC boost
Re: (Harassing Herbs)
what is the link to HMO? i want to do a swap with my 95 ex. i have the SOHC VTEC i wanted to boost, but with 200k im just asking for trouble. i want a b series
Re: b16 or b17 (RottenEggJDM)
if u can find a b17 that came out of a 1992 integra then BUY THAT ****!!!! thouse are the best gsr motor that acura has ever had i work for an acura dealer as a tech there and you dont know how many updates we had to do to those ecu's because the ecu couldnt take what the moter gave to it i know parts are hard to find but u do the swap right u will be running neck and neck with hatches with h22a's in them man just make sure that if u are going to to internal work make sure that u build the top and bottom end and make sure that is chiped right
Re: b16 or b17 (DohcVtec1.6-1992)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DohcVtec1.6-1992 »</TD></TR><TR><TD CLASS="quote">if u can find a b17 that came out of a 1992 integra then BUY THAT ****!!!! thouse are the best gsr motor that acura has ever had i work for an acura dealer as a tech there and you dont know how many updates we had to do to those ecu's because the ecu couldnt take what the moter gave to it i know parts are hard to find but u do the swap right u will be running neck and neck with hatches with h22a's in them man just make sure that if u are going to to internal work make sure that u build the top and bottom end and make sure that is chiped right </TD></TR></TABLE>
People in Fairport are in trouble if they go to that dealership
The B17 had a favorable rod ratio, but the low compression is a downside if you're going N/A. Plan to swap out the pistons if you do pick it up.
Re: b16 or b17 (Cult of Staxx)
its your choice they are both decent motors but finding a b17 with lower miles is gonna be hard since they were only produced in usdm 92-93 integra gsrs
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Cult of Staxx »</TD></TR><TR><TD CLASS="quote">
The B17 had a favorable rod ratio, but the low compression is a downside if you're going N/A. Plan to swap out the pistons if you do pick it up. </TD></TR></TABLE>
LMAO, i agree.
LMAO, i agree.
Re: b16 or b17 (LiL Jon)
screw d series, screw b series, screw the h22 and screw the k series. if you want speed then go jet engine. yeah, you have the jet lag of it needing to speed up, but just think, what other civic will have a 1.2 mile per second?
hope i helped
hope i helped
Re: b16 or b17 (lvcompetition)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lvcompetition »</TD></TR><TR><TD CLASS="quote">i would say b16 less trouble,, and by the way i just did my swap d16y8 and will turbo later with turbo what cars may i beat???</TD></TR></TABLE>
Explain how the B16 is "less trouble"? Come on, do it. This whole thread is full of crap. For one, the B17 head is the same as a first gen B16 head. Its no different because the B17 IS a B16 with a longer stroke. The crank, rods, pistons, and cams are different.. Other then that, its the same.
Someone said parts are hard to find... how is that when all B series parts will work just fine for it? I fail to see the point of that post.
The guy who works for Acura, your a tard and obviously don't work on the line by the way you are talking. If you are a line tech then people are in great trouble if they go to your dealership, as has already been said... And just a little help for you, the engine can't "throw" stuff at the ECU that it can't handle.
Between the two engines, the B17 IS a better platform then the B16. People can bitch and moan all they want... fact is it makes more torque (although not much) and the same hp in stock form as a B16. Up the compression to a reasonable level and it will always outperform a B16 with comparable mods... and by a good margin. If you can find one, pick it up. Its not difficult or expensive to rebuild the engine, so who cares about the mileage?
Re: b16 or b17 (4door)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4door »</TD></TR><TR><TD CLASS="quote"> not all b series parts are interchangable, my old jdm b16 had a strang water pump, the only one that would fit was a b17 water pump. </TD></TR></TABLE>
Thats pretty strange considering there is a B16 water pump sitting on my B17 right now. Been working for thousands of miles just fine.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4door »</TD></TR><TR><TD CLASS="quote">thats strange what year b16 was it mean't for</TD></TR></TABLE>
hmm are they not all the same?
