B series throttle body on a D series motor
Old 06-16-2007, 02:14 PM
motormike40's Avatar
Default B series throttle body on a D series motor
i wanted to know if you could take a B series throttle body and put on the D16z6 motor? can it be done?? if you know please let me know
Old 06-16-2007, 02:16 PM
krout206's Avatar
Default Re: B series throttle body on a D series motor (motormike40)
it can be done...all B and D series throttle bodies have the same bolt holes
Old 06-16-2007, 02:33 PM
thanks man.... do you know the size of the stock d16z6 throttle body??
Old 06-16-2007, 02:39 PM
MonsterB20Ek's Avatar
Default Re: (motormike40)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by motormike40 &raquo;</TD></TR><TR><TD CLASS="quote">thanks man.... do you know the size of the stock d16z6 throttle body??</TD></TR></TABLE>
no but u can google it more than likely
but i know for a fact u can put a BSeries T/B on a Dseries
not sure if D fits on B tho... should but why when its smaller
Old 06-16-2007, 02:44 PM
good, my brother has a grs motor with the b20 bottomend, and he give me the 65mm t/b for it!!! that makes me happy that i can get more power out of the sohc
Old 06-16-2007, 02:48 PM
Syndacate's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by motormike40 &raquo;</TD></TR><TR><TD CLASS="quote">good, my brother has a grs motor with the b20 bottomend, and he give me the 65mm t/b for it!!! that makes me happy that i can get more power out of the sohc</TD></TR></TABLE>
Putting that throttle body on your motor will DECREASE your power.
The reason is that the intake manifold isn't port matched. Without the IM being bored to the same size more air will come through the throttle body and hit a bottle neck when the IM intake port is smaller. This will create turbulence in the intake port of the intake manifold and the throttle body which will decrease your air flow.
With your airflow decreased you will lose power. A larger throttle body only works if your intake manifold is port matched or bored larger.
Old 06-16-2007, 02:51 PM
Ek Forever y0!
Libertariat's Avatar
Default Re: (Syndacate)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Syndacate &raquo;</TD></TR><TR><TD CLASS="quote"> A larger throttle body only works if your intake manifold is port matched or bored larger.</TD></TR></TABLE>
x2. Only way to make it work appropriately.
Though if your motor is stock, the only thing you'll notice is a little increase in throttle response.
Old 06-16-2007, 02:55 PM
big-cat's Avatar
and NOT ALL B-SERIES TB's work. there are certain one's that will, i really am not sure but i think a b16's will work as well as b18b and b18c5, dont quote me on those.
p.s. please search before you post.
Old 06-16-2007, 02:57 PM
Syndacate's Avatar
Default Re: (ek forever guy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ek forever guy &raquo;</TD></TR><TR><TD CLASS="quote">
Though if your motor is stock, the only thing you'll notice is a little increase in throttle response.</TD></TR></TABLE>
He won't even notice that, the increased turbulence will slow air flow through the intake port so it'll lower the power at top end slightly. If it was port matched it would help a bit on throttle response, you're right, but nothing really noticeable power wise on a SOHC.
Old 06-18-2007, 02:37 PM
92civicfreak's Avatar
is there anything such as too big? i just got a y8 IM & planning to put it in, but i want to get a b-series tb, & dont really know what one to put in... i want something cheep but is still good to run on the obd1 jdm d15b....
Old 06-18-2007, 05:09 PM
Ek Forever y0!
Default Re: (92civicfreak)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92civicfreak &raquo;</TD></TR><TR><TD CLASS="quote">is there anything such as too big? i just got a y8 IM & planning to put it in, but i want to get a b-series tb, & dont really know what one to put in... i want something cheep but is still good to run on the obd1 jdm d15b.... </TD></TR></TABLE>
What mods? If it's stock, leave the stock one.
Yes, you can make it too big.
Old 06-18-2007, 07:42 PM
its a jdm d15b header/exhaust... now waiting to go onto the car is a y8 IM... plan to go N2O
Old 06-19-2007, 01:11 PM
bump?
Old 06-19-2007, 06:50 PM
DIY16KID's Avatar
break out the dremel an start cuttin, im doin mine 4mm over to go to 60, then port matching the runners. gonna tryina straightin them out to. im thinkin about runnin nitrous but aint shure yet. what shot are you gonna run?
Old 06-19-2007, 07:15 PM
i have no clue.... this is way down the road... prolly b/4 a swap... just wanna know what the little D can handle :D
Old 06-19-2007, 07:27 PM
Toroke's Avatar
b18c1-60
b18c5-62
b18a-58
b18b-60
b16a SiR-58
b16a Sir2 / b16a2 / b16a3-60
b20b/z-60
f20c-62
d15b7-56
d16a6-55
d16y7-56
d16y8-56
d16z6-56
ZC-55
d16a1-55
d16a8-55
h22a / h23a-60
f22 / f23-60
Sizes in millimeters.
Unless you really know what you're doing, do NOT port your own manifold. If you change the sizes on the runners enough (which is quite possible), some cylinders can run leaner. This, in turn, can make it run hotter. If you couldn't put it together yet, this is bad.
Save it for the professionals.
Edit: It's sort of unclear what I said. I don't mean how much you change the size from the original state, I mean variations in the size in between the runners. For example, runner 1 might be much bigger than runner 3.
Modified by Toroke at 10:24 AM 6/20/2007
Old 06-20-2007, 11:37 AM
ALLMOTOR EK's Avatar
Default Re: (Toroke)
i have a Y8 with intake/header/exhaust. So you guys wouldnt recommend me putting a gsr tb on?
Old 06-20-2007, 11:39 AM
Ek Forever y0!
Default Re: (ALLMOTOR EK)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ALLMOTOR EK &raquo;</TD></TR><TR><TD CLASS="quote">i have a Y8 with intake/header/exhaust. So you guys wouldnt recommend me putting a gsr tb on?</TD></TR></TABLE>
If you have it professionally port matched then sure, you'll notice a tab bit more throttle response, but for the money you'll spend you could start piecing together a turbo.
Old 06-20-2007, 11:59 AM
ek4h's Avatar
it works but not worth it at all just save money and time for upgrades to the car
Old 06-20-2007, 12:00 PM
Default Re: B series throttle body on a D series motor (ek4h)
true, Thanks guys
Old 06-27-2007, 08:38 PM
truevietluv636's Avatar
Default Re: B series throttle body on a D series motor (ALLMOTOR EK)
i got a vx d15b... would a d16z6 throttle body fit?
my vx throttle body is hella small and i want to put an intake on but nobody makes it for vx so i was thinking if it was possible to swap over for the d16z6. will i lose any power?
Old 06-27-2007, 09:49 PM
highrev1987's Avatar
Default Re: B series throttle body on a D series motor (truevietluv636)
80 percent of them fit, and just grab some porting tools
and match it
Old 06-27-2007, 10:19 PM
Syndacate's Avatar
Default Re: B series throttle body on a D series motor (highrev1987)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by highrev1987 &raquo;</TD></TR><TR><TD CLASS="quote">80 percent of them fit, and just grab some porting tools
and match it</TD></TR></TABLE>
Yeah, if you're gonna slap the throttle body on, even if it's not the proper way, take a dremel bit and widen the port a bit on the intake manifold. Bigger TB w/ regular intake manifold intake port = slower air flow due to turbulence.
Old 06-27-2007, 10:25 PM
Unceasing Measure
Archidictus's Avatar
PS - do this off the car so you can clean the 900 million metal shavings out of your manifold before you start the car and foul your oil and ruin your motor
Old 06-27-2007, 10:32 PM
orb
orb's Avatar
I was just reading about this, and what the guys above are telling you is correct:
"Over-sized throttle-bodies offer a larger diameter opening and flow more air. Is this a restriction in the system? If your engine... won't flow anymore air, then the larger throttle body can't help. In fact, it may hurt off-idle performance. Once you do make changes to allow the engine to flow more air, it can help make more power. Keep in mind, when you improve airflow, you must also calibrate the fuel flow to match, or you're not going to make more power."
High-Performance Honda Builder's Handbook -Joe Pettitt
SoHc94
03-11-2007 06:03 PM
KURUPTinc
07-29-2005 03:12 PM
keepitjdm
04-13-2005 02:40 PM
89 pos
11-23-2004 08:31 AM
Quick Reply: B series throttle body on a D series motor
