axle nut size on EG
axle nut size on EG
wat's the size of the front axle nut? its a dx hatch if that makes a difference (doubt it but wanna check).
searched and found nothing. just need to be sure b4 a single socket is bought.
is it 22mm?
TIA!
-Dan
is it 22mm?
TIA!
-Dan
Re: axle nut size on EG (S14sx2nr)
32mm or 1 1/4 sae will work the standard 1 1/4 is a little cheaper if u r concerned bout money. I beleive the 1 1/4 is a **** hair bigger but its what i have and no problems at all.
thanks =Gameova= <--please press =pause= since u have nothing to contribute
and i did, it was a blast, cant wait till i get to do it again ... ... *rollseyes*
-Dan
-Dan
Re: (S14sx2nr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by S14sx2nr »</TD></TR><TR><TD CLASS="quote">thanks =Gameova= <--please press =pause= since u have nothing to contribute
-Dan</TD></TR></TABLE>
lols i was giving you a heads up. what u want me to say, 32mm for the 50 million time?
btw: what people do you see roll their eyes?.....
Re: (S14sx2nr)
I tried impacts on my 97hb and it didn't work at all, so we tried muscle and couldn't jam the hub to stop it from spinning. Sucks to be me!
Re: (spnfed)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spnfed »</TD></TR><TR><TD CLASS="quote">I tried impacts on my 97hb and it didn't work at all, so we tried muscle and couldn't jam the hub to stop it from spinning. Sucks to be me! </TD></TR></TABLE>
ah you girly man you. i guess we're really strong or really lucky
did the center of the hub nut have a little cotter pin or something that u have to get out first? have your buddy nail the brakes while u do it...not really the best way to do it, but it makes it easier...
and gameova, lol, sorry im tired, and cold, not a great combo, and i see lots of kids roll their eyes at their parents...thats funny stuff.
who said, thanks for repeating wat scrambledeg said.
-Dan
-Dan
Re: (S14sx2nr)
do you have to do something special to the nut? for some reason my stock nut has a little endent in it? i can take a pic if you want me to. Does anyone know why? and if u replace the, do you have to make that same mark?
that little indention you're talkin' about is just a safety mechanism to keep the nut from backing off the hub if it ever got loose. It is a 32 mm nut and the easiest way I've found to get it off is to take a long metal pipe and slip it over the end of your socket wrench with the 32mm socket on it....gives you ALOT more leverage than you'd otherwise have with half the effort.
BTW, it's recommended that whenever you take an axlenut off, you replace it rather than reuse it....that's just what I'm told so it's what I do. But when you do put it back on, make sure it's torqued down to spec and once it is, take something an pound the lip into that indention on the hub...Good Luck
Former Moderator
You guys want some good axle install info?
Ever hear a clicking noise when you turn?
Ever feel a vibration only when you're acclerating?
Chances are that you need a new axle. The first thing you'd need to do before you go pulling an axle out of your car is figure out which axle is bad if both aren't. Symtoms of a bad axel would be:
1. Torn boot with grease slinging out. ( :hammerDUH:hammer )
2. One side or the other vibrating upon hitting the gas. This indicates a broken or worn inner joint.
So after you figure out which one (or both) needs replacing you can begin.
I've taken some pics of various tools that you will need in order to swap an axle. I work at a shop so air was available to me, but for you at home there might not be some tools pictured here that you will need - I'll get to that in a minute.
32mm socket
19mm socket
17mm socket
17mm wrench or additional socket
1/2'' driver for big sockets
3/8'' driver for drain plug/sockets
hammer
dykes
prybar
*big-*** breaker/cheater bar for the 1/2'' driver to break the axle nut loose and tighten it back down*
*Optional*
Depending on tranny you might have to drain and fill the tranny. I make this a common practice every time I swap an axle and I recommend that you do too. In my tutorial I will detail how to drain and fill the tranny. If doing so add these things:
3 qts of Genuine Honda MTF (you won't use all 3 - B-Series takes like 2.5 qts.)
Long funnel
crush washer for drian plug (get it from Honda - same one as your engine oil drain plug)
10mm socket with LONG extention
driver for 10mm socket/extension
Here we see the various tools laid out. Missing from the pic is the big-*** breaker car for you at home that will need it for the 32mm axle nut. Also missing are the funnel and 10mm socket.extention/driver combo for the drain/fill procedure. I has air tools available so I used them.
Close-up of cotter pin (you'll only need one) and drain plug washer
Drivers and 17mm end wrench:
32mm, 19mm, and 17mm sockets:
And if you're lucky and have tools a 1/2'' impact will be very helpful:
Okay so let's get started.
1. Take the 19mm socket and break your wheel lugs loose. they will be hard as hell to break loose if you've already got the car in the air.
*For those without an impact*
It has been brought to my attention that if you are using a 32mm socket with a 1/2'' driver and a big-*** breaker bat you might want to break the 32mm axle end nut loose while the car is still on the ground. Hopefully you can access the nut with the wheel still on, because if not you'll have to get someone to sit in the car and hold the brakes on with the engine on in hopes that the wheel won't turn while you try to break the 32mm nut loose.
2. Jack up the car and secure it on a STABLE set of jackstands. I used a lift so sorry, no pics.
3. Locate the drain plug and use a 3/8'' driver with no socket and remive the drain plug:
Replace the drain plug washer and tighten the drain plug back after draining is complete. I didn't do this until later on because I waited to drain the tranny until right before prying out the axle, but I recommend doing this first at home and then tightening the plug back until you feel/hear the washer crush. This insures no leakage during work and also so that you remember to drain and tighthen the plug up before you start the real work.
4. Remove the wheel and look for the 32mm axle end nut. Yeah the pic sucks.
5. Remove the axle nut with the 32mm socket. At home you will need a breaker bar or cheater bar to get much-needed leverage to break this bastatrd loose. I used an impact.
6. Now find the cotter pin lovated on the 17mm castle nut below the lower balljoint and remove it by unfolding it with your dykes:
7. Now take the 17mm socket and remove the 17mm castle nut from the lower balljoint. Yes this pic sucks too.
8. Now take your hammer and beat on the lower control arm where the hammer head is in this pic. This will break the balljoint loose. The pics get better sometime.
9. Now locate the through bolt that holds the lower strut "fork" to the lower control arm:
10. Using a 17mm socket on one side and either a 17mm wrench or another socket to hold the other side, remove the through bolt .
11. Now take your hammer and LIGHTLY tap on the end of the axle to get it free from the spindle:
12. Now pull the lower strut fork to the side and it should all look like this:
13. Now you're ready to pry the axle out. Take the prybar and position like so in the pic and pry. You might want to secure the spindle out of the way so it doesn't hold the axle in:
14. Compare your new axle to the one you pulled out and make sure the new axle is correct. The old axle might not "look" bad, but in this case here the shaft is actually broken in half inside the outer boot.
15. Now you're ready to put the new one in. Simply reverse the removal procedure. First get the spindle out of the way and pop the axle back into the inner joint. It might take a bit of pushing, but it will pop in. Make SURE that the inner joint is all the way in and butted up against the tranny casing fully.
16. Here's where steps can be swapped around, but I did mine in this order. Put the lower balljoint back into the lower control arm and slide the outer splines back into the spindle - finger tighten the 32mm axle nut on so the axle doesn't pop back out while you do other work.
17. Now you're ready to line up the lower strut fork with the lower control arm to put the through bolt in. It helps to tighten the lower balljoint 17mm castlenut first. Replace the cotter pin too! VERY IMPORTANT!!! Remember to tighten the 17mm castlenut in a manner so that you can slide the new cotter pin in.
18. Push up on the lower control arm and slide the through bolt in plave and put the 17mm nut on the end:
19. Using two 17mm sockets or whatever combo you choose, tighten the through bolt:
20. Now tighten the 32mm axle end nut. If you have no air tools then use the breaker bar and tighten it up pretty snug. STAKE THE NUT DOWN! Use the hammer and something flat to make an indention in the nut like pictured:
So the new axle is in. Time to fill the tranny. There's a few schools of thought on how to fill the tranny, but this methid here is by far the least messy and to me the easiest.
*Optional* Find the fill plug. It is seen here right next to the inner joint of the axle. It has a crush washer so if you loose it your'e screwed. Honda doesn't usually sotck this one. I chose not to loosen my fill plug because I know my tranny takse 2.5 qts., but the way you fill it is to fill until fluid dribbles from the fill hole so this is optional if it makes you feel better.
Here's where the trick comes in that will save you headahces. Usually you have to ghetto-rig a funnel and tube to fill the tranny in the fill hole which really sucks. My method is really easy.
1. Remove the vent cap found near the front/top of your tranny:
2. Find the Speed sensor located on the topside of the very back of your tranny:
3. Take the 10mm on a big-*** extension and remove the bolt (it's the orangish one in my pic - yours probably won't be oragnish):
4. Now see that big-*** hole left after you move the speed sensor out of the way? Use the funnel and fill through that hole! By the way, no need to unplug the speed sensor - just move it out of the way.
5. Fill up with specified amount or until fluid dribbles from the fill hole below.
6. Put the speed sensor back in, tighten up the fill plug (if you loosened it).
7. Replace the vent cap and you're done!
Now put your wheel back on, torque the lugs to spec with a torque wrench and take your car for a test drive!
I will check later for typos, but for now I have to run. Hope this helps you all with axle questions!
32mm socket
19mm socket
17mm socket
hammer
dykes
prybar
*Optional*
Long funnel
when i did my swap, i couldnt get the castle nut off of my drivers side balljoint, so instead i dropped the upper control arm(2 nuts located near the upper strut mount thing) and completely removed the strut allowing me to swing the top of the spindle out of the way so i could remove the axles
4ghatch
05-27-2003 08:38 AM
