Axle Compatability
Old 02-23-2004, 02:29 PM
vha27's Avatar
Default Axle Compatability
Ive swapped a z6 into my 92 cx, with a d16y8 tranny. will the stock 92 cx axles work? i cant seem to pop the axles in all the way
thanks,
chris
Old 02-23-2004, 05:54 PM
vha27's Avatar
Default Re: Axle Compatability (vha27)
help please
Old 02-23-2004, 05:55 PM
slammed_93_hatch's Avatar
same foo try harder,
ps. id rather swap motors then change axels i always seem to run into stupid *** problems
Old 02-23-2004, 06:02 PM
Option's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vha27 &raquo;</TD></TR><TR><TD CLASS="quote">Ive swapped a z6 into my 92 cx, with a d16y8 tranny. will the stock 92 cx axles work? i cant seem to pop the axles in all the way
thanks,
chris</TD></TR></TABLE>
Yeah the axles should work, but i may be wrong, the rule of thumb i always go by is d-series with d-series, B-series with b-series, h-series with h-series so on and so forth.
but i may be wrong.
Old 02-24-2004, 05:34 PM
vha27's Avatar
Default Re: Axle Compatability (Option)
even without the snap ring in place, it wont push all the way in
Old 02-24-2004, 06:17 PM
Sketch_hs's Avatar
try harder.
nah, sometimes the axles don't "want" to go in. Keep trying i've spend over 20 min before working an axle in, sometimes they just pop in, sometimes you gotta smack'm round a bit.
Try rubber mallet, don't touch or compress the boots though. worked for me before.
Old 02-24-2004, 06:32 PM
ekb18cCivic's Avatar
Default Re: Axle Compatability (Sketch_hs)
have you ever installed axles before?? all d series are interchangable.. expect auto - manual and ABS to non ABS... put the axle in place turn it a lil to you feel it catch then put a piec of wood over the end and tap it with a hammer it should slide right in...
Old 02-24-2004, 07:31 PM
Mr. Badwrench
boostedcivicsir's Avatar
Default Re: Axle Compatability (ekb18cCivic)
CIVIC STD axles are not. just to add that 88-91 civic STD and crx hf axles are different. the hub splines are smaller. not to shanghai this thread i just wanted to add that. cx axles should work on your application.
Old 02-25-2004, 04:40 PM
vha27's Avatar
Default Re: Axle Compatability (boostedcivicsir)
yea ive installed axles before, it finally worked, just take a long 2x4 and brace it against the axle part near the tranny, one good whack with a sledge hammer and it pops in
thanks everyone
chris
InTheLBC
02-10-2008 09:07 PM
hoggy
11-16-2005 11:37 AM
esteps
12-22-2004 09:08 PM
80884
11-23-2003 10:12 AM
Rev-Olution
09-21-2003 05:39 PM
Quick Reply: Axle Compatability
