AVID MOUNTS ISSUE
AVID MOUNTS ISSUE
Hi guys, i have a '94 eg hatch with b16 engine , and bought ac.mm.004 avid mounts, but i have a few difficulties trying to install the driver side mount without any modification...Is this ever be possible?
The mounts i mean is the one in the pict. Any suggestion?
Thks
Thks
Re: AVID MOUNTS ISSUE
what exactly is your issue? are the bolts not lining up? do you have the right post? is your motor being supported in the air as youre trying to put the new mount in? im shooting in the dark with your description
that looks like a trans mount. drivers mounts are usually 2 post with a slight offset on 92-2000. 88-91 have a large offset.
by offset i mean difference in the post holes passenger to driver side
drivers below
drivers below
^wow really? tranny mounts look quite different, its for sure a motor mount, maybe the OP has a different post than what the mount is looking for.
hasport b-series eg mount:
http://hasport.com/store/index.php/m...s-eg/dclh.html
they sell a 3 post(which i have never bothered to notice), have always used a 2 post for the B swaps.
i believe they sent the wrong mount.
B Series Kit for 92-95 Civic/93-97 Del Sol (2 hole style) AC.MM.004 $279.98
B Series Kit for 94-01 Acura Integra (3 Hole style mount) AC.MM.004DC $279.98
ha, here it is....
take a pic of the part number and post it up.
ha, here it is....
the engine is on dolly and the holes on the mount are to lined up with the studs on the engine! Light on now?
This is the mount i need. engine come from a 94 hb. I think the boxed up this mount for an error in my box.
That is def a motor mount and not a tranny mount.
And yes it does look like its for a dc.
Easiest way to do it is by returning the product or getting a 94-01 Integra post mount.
The other mounts, left trans mount rear enggine mount and torque mounts are fitting ok, as i said they boxed up this mount in a wrong set
you know you can pull the mount off another motor (94-01 teg) if there's a junkyard or parts car nearby in less than 20 minutes and it shouldnt cost you more than bout 15USD
looks like a mount used on ek chassis by how the holes are. my civic si has the post mount that parallel to the block and that mount would fit that
i dont know why but i think they gave you the wrong part
you cannot use a new post because the ek posts sit closer to the front of the vehicle while the da/eg one sits farther back
Yes like stated, the b16 is a 2 bolt and gsr's is a 3 bolt. I think what was mentioned was to get the bracket off of a gsr motor that has the 3 studs on it to work with your mount since that would be cheaper then ordering another mount
