Autozone Brake Rotors: Who's using them?
1. How many miles?
2. Do you use them for track, street, or both?
3. How do they compare to stock rotors in terms of durability and performance (i.e. rotor warping, brake fade)?
I'm at 155K on a 00 Si with stock original rotors (moderately warped). I resurfaced them once at 125K, and were never resurfaced before then. I'm the original owner as well.
So I could buy a generic pair of blanks at Autozone for $50.00 or online at Honda for $110.00. Any problems with the Autozones for 40-60K miles? Thanks in advance.
EDIT: Links given for reference...
http://autozone.com/servlet/Ui...C%7EB
http://www.hondaautomotivepart...82%29
Re: Autozone Brake Rotors: Who's using them? (Design)
Buy some brembo blanks from the marketplace bro, Can find em cheap there!
I swear I found a pair of 2, for 60$ + shipping, It was awhile ago, but check around there...everyone sells them.
There's probably not too much of a difference between rotors from a parts store and then from Honda. They're not drilled/slotted and the same diameter... I'd be more curious about the brake pads.
Re: Autozone Brake Rotors: Who's using them? (Grip King)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Grip King »</TD></TR><TR><TD CLASS="quote">There's probably not too much of a difference between rotors from a parts store and then from Honda. They're not drilled/slotted and the same diameter... I'd be more curious about the brake pads.</TD></TR></TABLE>
Def true, butcant beat name brand for cheap...
Brake pads are OEM. I'm more concerned about brake fade resistance and heat dissipation on the Autozone Rotors (or similar). For those using them, how are they holding up?
Iv had mine for about 30k and they are doing just fine. cant beat the price either. but they are for the rear... I havent put anything on the front yet
I bought a set of Brembo blanks from this thread, can't be happier, though I'm only 4K in. Ultimate pads are ridiculously dusty, but I knew that going in.
Based on what the AZ website is listing for my car I got a complete set of name-brand rotors & pads - shipped - for less than it'd cost to buy a pair of generic rotors. Hopefully your car is less...
(edited for clarity)
Modified by MonkeyBoy668 at 4:35 PM 6/7/2006
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Design »</TD></TR><TR><TD CLASS="quote">$20.00 more for Brembo blanks is not bad at all. Thanks for the link. </TD></TR></TABLE>
did i miss something...where is the link
i currently am using AZ brand rotors...i think for street they are ok...but for track it is not good because it will not be able to handle the heat...i know i found a thread once that someone made about cheap rotor for track purpose...it look pretty bad...i wish i can link it. so you can see it...
im running some kragen rotors with some pbr eramic pads and mine are woking fine. use it for street and track holds up great.
Re: Autozone Brake Rotors: Who's using them? (fmrprojects)
How many miles so far?
Full Brembo link from the above post: https://honda-tech.com/zerothread?id=1411597
1 Post
i have used auto parts store generic rotors before on the drag strip, autox, track, and street. they work just fine. i would advise sticking with a honda or performance aftermarket pad (project mu...). the rotors worked great and do not warp any more than a stock rotor will. if you want to get a rough idea of how the rotor will deal with the heat, and be resistant to warping, weigh it, the heavier the rotor, the better.
Re: (littleredcivic)
Yeah, to a certain extent there's really not a whole lot of "tech" to regular Honda brake rotors - they're just cast iron alloy parts. The important thing is that the metal be a consistent density across the face of the rotor. The less consistent the mixture, the more often they'll need to be resurfaced.
This isn't very high tech, but I've had aftermarket rotors that needed resurfacing more often than I'd like. I'm not sure what, if any, differences there are between the 1yr AZ rotor & the 3yr AZ rotor...
1 Post
Some people don't drive like maniacs and their brakes last forever. My mom went on stock rotors and pads until 102k. But on the other hand, I do drive like a maniac...my WRX has 11k miles and I will need pads soon.
Re: Autozone Brake Rotors: Who's using them? (MonkeyBoy668)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MonkeyBoy668 »</TD></TR><TR><TD CLASS="quote"> Ultimate pads are ridiculously dusty, but I knew that going in.</TD></TR></TABLE>
I just threw those pads on my car today, wtf, I thought ceramic pads were suppose to dust significantly less..
Location: Dont You Just Love Lynn Cops, Boston MA, USMA
i have Autozone Rotors they feel like they dont wanna grab that good until you slamm thr brakes. i bought them because they are life time warrenty
Re: Autozone Brake Rotors: Who's using them? (Hondaciv95VX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hondaciv95VX »</TD></TR><TR><TD CLASS="quote">
I swear I found a pair of 2, for 60$ + shipping, It was awhile ago, but check around there...everyone sells them.</TD></TR></TABLE>
Don't kid urself, u get what u pay for no matter what, found rotors for my Jetta (b4 I sold it) $25/rotor, yeah, about 1 month they're warped (and still on the car I might add...)even though they look stock in every way, shape, and form, can't tell the diff between them and a vw rotor, it's a total get what u put in system..
Munkyw3rkz.webs.com
1 Post
nothing wrong with autozone black.... ran it on both my EG adn DC.. the DC had NSX calipers front and rear with hawk pads.. worked great with no problems!
Re: Autozone Brake Rotors: Who's using them? (Syndacate)
You get what you pay for, yes and no.
If you can find the exact same product for less money from Vendor A vs. Vendor B, it doesn't mean you're getting any extra "value" by bending over and taking it from Vendor B.
Brembo makes quality products. They make the rotors for some OEM vehicles. They're way up there my the list when it comes to manufacturers of quality aftermarket parts.
But don't get me wrong: 99% of what's available on eBay is worthless crap that won't last for more than a month. But just because people buy worthless aftermarket crap from there doesn't mean all non-OEM products are crap.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Grip King »</TD></TR><TR><TD CLASS="quote">There's probably not too much of a difference between rotors from a parts store and then from Honda. They're not drilled/slotted and the same diameter... I'd be more curious about the brake pads.</TD></TR></TABLE>not true. oem stuff has a lot stricker production credentials and they use better materials. i had autozone rotors. i got them for 20 dollars for my civic. they warped the second day i had them. i dont think the oem honda rotors would have wapred.
