arp headstuds d16y8
arp headstuds d16y8
i have a built d16y8 and was planning on running 18psi and just wondered about how to install the arp headstuds. the instuctons said something about a water jacket and to use sealant. what do i use for sealent? teflon, of threadlocker?????? or do i just put the studs in hand tight. does anyone know what im talking about?
Re: arp headstuds d16y8
i just bought some ARP head studs and remember reading the water jacket thing.. but i think that's for engines where the studs themselves are exposed to coolant. hondas are not this way. (this is my assumption... contacting ARP is the best thing to do)
definately use the lube that comes with the studs, and otherwise follow their instructions.
hope you invested in a good head gasket like a cometic. be sure to follow torqueing order and start at low torque then work your way up to what they are suppose to be. let the car run tell its full operating temp then crack the nut loose(not completly loosen it just tell they crack)then retorque one at a time.
i need help with mine also I have arp head studs an there about an inch to high did I put them in wrong or something ik there not upside down cause the key lock on them please help any feed is thankful
First off, create your own thread, don't bump a 4 year old, dead, unrelated thread.
Second off, if they're all an inch too short, you ordered the wrong studs.
92_civic_eg
Engine Machining & Assembly
08-27-2016 07:24 AM
