Apex'i turbo installed... Blow off valve questions/ availability
I have an Apexi turbo for may 95 civic ex and want to know 1 if all weld application blow off valves MUST be welded or can they be bolted.
2 - I would like to know what all bolt on BOV are available for it.
Thanks
By the way, I am SPOOL, using UndercoverSI's id screen name.
[Modified by undercoverSI, 12:57 AM 5/25/2002]
[Modified by undercoverSI, 12:58 AM 5/25/2002]
Thanks
Re: Apex'i turbo installed... Blow off valve questions/ availability (undercoverSI)
Any bov that you want to run will work. And they all require that you weld a flange on.
Doesn't the Apex kits come with a flange for the BOV already welded on? If so, then I would probably stick with an Apex BOV just to make your life easier. Unfortunately, I don't know what other brand of BOV's fit.
