Anyone WIth NOS>.....on their B16.....give me some . advice before i destroy it.
New User
Got my 55 shot of Dry nos system install. NOw what should i do to improve the performance of the nos? what other parts should i replace so the motor holds out longer?? I was thinking about doing up the head .... cams, gears, etc.. any advice that will keep my civic alive ... welcome
Re: Anyone WIth NOS>.....on their B16.....give me some . advice before i destroy it. (ElectricBlu
colder plugs, new plug wires. use the nitrous sparingly and dont spray for more than 15 seconds. the cams and gears wont help your engine last longer, but will help power wise. if you want to run a high shot, then you need to build up the ening. pistons, rings, stuff like that. but you will eb fine with a 55 shot ona b16 a long as you dont use it at every other stop light.
the motor should hold together if you are running a 55 shot. just make sure the car is running good. good fuel and air ratio's are key..........
