Anyone has pics of del sol dohc shift linkage and 99-00 Si for comparison?
Anyone has pics of a del sol dohc shift linkage and 99-00 Si for comparison?
Re: Anyone has pics of del sol dohc shift linkage and 99-00 Si for comparison? (BlueIntegraBoy)
the del sol is longer, you could just cut them in half, install them hold the shifter in center, add metal in between, weld and then paint. when I did my b16 the linkage i had was from a delsol, i had to cut the linkage.
Re: (Suck my DX)
so you just cut, measure, and reweld and it should be good? im going to be swapping my gsr from my del sol to my eg and i hadn't heard of this before so any info would help. thanks ahead of time.
Re: (midnitesol)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by midnitesol »</TD></TR><TR><TD CLASS="quote">so you just cut, measure, and reweld and it should be good? im going to be swapping my gsr from my del sol to my eg and i hadn't heard of this before so any info would help. thanks ahead of time.</TD></TR></TABLE>
pretty much...i cant remember if i had to cut both pieces or not...either way it shouldnt be too difficult...just make sure that the shifter sits straight in the cabin before you reweld it...lol the first time i made one it came out with a mean gangster lean...hahaha
as far as shortening it, remove the material from the straight portion of the linkage...you dont need to be super exact with the length...there is about 2 inches of adjustability, but its always good to double check before you weld...hope that helps some
powerline707
06-16-2011 01:41 PM
skiracer8148
03-17-2007 05:09 PM
