ANOTHER thread about the famous clutch to the floor
I searched and only found info about the clutch sticking to the floor. Well mine has little pressure and sinks to the floor but comes back up.
Its been like this for god knows how long. I swaped my motor with a jdm d15b and it had a newer clutch, I still had the problem. I also kept my d16z6 tranny on. I knew my clutch master cylinder was leaking so I just replaced it and my slave. We bled the clutch for awile and it still has little pressure and goes to the floor.
Any idea's?
Any idea's?
Re: ANOTHER thread about the famous clutch to the floor (DSRxNATE)
Where else could it be leaking at?
I know when i push the clutch down, theres a weird squeaking noise coming from the master cylinder.
Re: ANOTHER thread about the famous clutch to the floor (DeadEnd9009)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DeadEnd9009 »</TD></TR><TR><TD CLASS="quote">make sure the lines are not leaking and that your reservoir is topped off.</TD></TR></TABLE>
This was my problem Friday night. Had no fluid.
Re: ANOTHER thread about the famous clutch to the floor (del sol1658)
you mean that your pedal pressure isn't as strong as other cars right? I have this same problem, my pressure plate is messed up.
Re: ANOTHER thread about the famous clutch to the floor (byronl)
Sound like air, but if the car goes into gear fine then you're good. don't worry about it.
Re: ANOTHER thread about the famous clutch to the floor (stock_honda_coupe)
Yeah, the pressure isnt as strong as other cars,and it goes into gear fine, and shifts fine. I just hate out my foot sinks to the floor lol.
Then you're good, if you want it better, you're going to have to replace the clutch.
hmm .. i was gonna first ask if its a cable or hyrdo.. Sounds like the clutch itself maybe be bad. like the sprung center spring.. U need to take the tranny off and inspect it.
akteamster
10
08-13-2004 04:13 PM
ibe2fly
07-10-2004 03:31 PM
