Another Random Misfire
Davis Photography
Hello... again.
<U>Today's topic is</U>: Random Misfire.
<U>Car</U>: 2000 Honda Civic EX, D16y8
<U>Symptoms</U>: Car randomly misfires in cylinder #1 and sometimes cylinder #3.
<U>Items Replaced</U>: Plugs, wires, cap, rotor, dizzy, traded ecu's.
<U>Setup</U>: Password JDM carbon fiber intake, Manual tranny conversion.
<U>Time</U>: Has been occuring for about a month, have been autoxing on and off.
<U>Compression Test Results</U>: Cylinder 1: 180 2: 185 3: 180 4: 185
I need help. Lmk what else you should know or any suggestions. thanks.
Re: (burnitdown)
Check for water in the cap, that happens a lot when people power wash their cars. Might want to check the BLK/YEL + wire to your dizzy coil for rust, if this gets corrosion in it, it will have a mid to high load miss. (mid to high throttle)
Re: (DrewMD)
my misfires got so bad it was like i was driving an sti found out later my head gasket was slowly messing up more and more until it was hard to start
Davis Photography
Re: (95DxSi-R2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95DxSi-R2 »</TD></TR><TR><TD CLASS="quote">lol, so what happened when u switched injectors?
miles on said vehicular......recently cleaned your engine?</TD></TR></TABLE>
I haven't driven on the switched injectors much. It hasn't randomly misfired yet. the car has around 54k miles. just did an oil change. i have not recently cleaned my engine.
Maybe a bad coil and/or ignitor(ICM)....?
Honda coil=poop (but will still work for 150k+, just not like it should) $45 dollars at o'rileys with a lifetime. Make sure the connectors are on tight and not slipped between the plastic and metal. Adn you should prolly swap one at a time just to be sure everything is right.
I also had a random misfire code and cyl 1 2 3 4 at idle but ended up being a combination of things.
1.OBX alt pulley...12.1 volts is NOT enough
2.mis-adjusted throttle linkage to compensate for low idle(see above statement)
When i put the stock pulley back on and adjusted my linkage, i installed a blox intake mani, cleaned injectors(150k), hondata intake gasket and a honda pcv(maybe 150k). My miss has been gone for months now...its great.
Davis Photography
Re: (ek forever guy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ek forever guy »</TD></TR><TR><TD CLASS="quote">Did you take a look inside the rotor/cap?
Is it pointing the way it's supposed to?</TD></TR></TABLE>
I recently changed out the cap and rotor, and installed it correctly.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tx_ej8_49 »</TD></TR><TR><TD CLASS="quote">Maybe a bad coil and/or ignitor(ICM)....?
Honda coil=poop (but will still work for 150k+, just not like it should) $45 dollars at o'rileys with a lifetime. Make sure the connectors are on tight and not slipped between the plastic and metal. Adn you should prolly swap one at a time just to be sure everything is right.</TD></TR></TABLE>
I switched out my dizzy for my known working brother's dizzy from the same motor type.
I know I adjusted the throttle cable when my throttle body plate was sticking. But the cord is loose, not taught.
how long ago did you do the tranny swap. i been told by my guy at honda that the egr valve can cause random misfires. i dont know if this is true but its what i been told before.since there is no egr now maybe that could be the problem.
* B A N N E D *
Re: (DrewMD)
check the boot around the p[art of the wire that touches the plug. and see if it isnt arcin in there becuase thats what happened to me once
Re: (Hybrid96EK)
Probably codes 70-74, each code represents a cylinder number, and the 70 is a random misfire all together that does not exactly occur in a specific order.
Re: (slowcivic2k)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slowcivic2k »</TD></TR><TR><TD CLASS="quote">Probably codes 70-74, each code represents a cylinder number, and the 70 is a random misfire all together that does not exactly occur in a specific order.</TD></TR></TABLE>
Code 70 is clearly displayed in the Helm as being a code for the automatic transmission (aka transaxle). I'd like to hear from the OP how he determined the misfire on those two cylinders still and not your speculation however...
