another newb question
318 Curves, 11 miles
Re: another newb question (nicrod)
Double-clutching is when you push the clutch all the way in, pull the car out of gear, let the clutch out, then push the clutch back in while rev-matching, downshift, and release the clutch. It takes a lot of practice. It is used on old transmissions that don't have synchros, and by people who watch too many Vin Diesel movies. It can still be used to skip gears on cars with lockouts (say downshifting from 5th to 2nd on last-gen GM F-bodies), but as far as I know does nothing for most modern imports, and does nothing in drag racing, since in drag racing you only upshift. The only thing I've noticed is that it makes it slightly easier to get it back in a lower gear, but that's probably more a product of rev-matching than double-clutching.
Re: another newb question (Vindicator9000)
hahahha vin diesel movies. "granny shifting instead of double-clutching like you should" i was like wtf. I wouldnt worry about double clutching unless your intense.
sad that greg liberman even let them put that phrase in teh movie, or blowing the welds of your intake
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Vindicator9000 »</TD></TR><TR><TD CLASS="quote">Double-clutching is when you push the clutch all the way in, pull the car out of gear, let the clutch out, then push the clutch back in while rev-matching, downshift, and release the clutch. It takes a lot of practice. It is used on old transmissions that don't have synchros, and by people who watch too many Vin Diesel movies. It can still be used to skip gears on cars with lockouts (say downshifting from 5th to 2nd on last-gen GM F-bodies), but as far as I know does nothing for most modern imports, and does nothing in drag racing, since in drag racing you only upshift. The only thing I've noticed is that it makes it slightly easier to get it back in a lower gear, but that's probably more a product of rev-matching than double-clutching.</TD></TR></TABLE>
Well said.
Well said.
Re: (AntF)
Oh, I forgot to say that it shouldn't be bad for your clutch, but it can make it easier to mess up your engine and/or transmission if you're not careful. Since double clutching bypasses the lockout (on some cars), and makes it easier to downshift at higher RPMs (on all cars), it's fairly easy to downshift into too low a gear, and come out at 10000 rpm or so, which is not healthy for most engines or transmissions. Just don't be stupid with it (try to downshift too far) and you'll be fine.
Re: (chargedek)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chargedek »</TD></TR><TR><TD CLASS="quote">Thats the funniest car movie ive ever seen</TD></TR></TABLE>
that was the saddest car movie ive ever seen...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nicrod »</TD></TR><TR><TD CLASS="quote">ok so im tryin to get into the tuner thing and i was wondering wat exactly is doubble clutching and is it bad for ur clutch</TD></TR></TABLE>
grammer nawzi
Re: another newb question (hondaeg8)
OP: that was the true form of a noob that watches too much God Damned ricer movies. I think I might sell my "import" after that question. Put on your flame suit!
The question was answered early, get a strong enough motor and you probably won't have to worry about need to "double clutch." I don't think it helps to be honest, perhaps it does.
Pretty lame question though dog...
