Altenator
Re: Altenator (koa)
no, a dead battery would....alternator could be the cause of a dead battery though. so through the 3 degrees of automotive electricity i guess you could say it could cause it.
Re: Altenator (koa)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by koa »</TD></TR><TR><TD CLASS="quote">my battery is reading 13 votls good connections...so in other words it it could cuz tht
i think there were two seizures that just took place, one while you were typing that and one while i was reading that.
Does the car start? chances are a bad alternator is not causing a fuel pump failure or a starter failure, if your batter is reading 13 volts while the car is running you are ok, it's a little low for charging voltage but not really condemnable...if it is reading 13 volts with the car off you are overcharging the battery in which case your alternator is no longer functioning properly.
Re: Altenator (koa)
sounds more like a fuse problem, that is if the starter and fuel pump went out at the same time, it's not very likely that two components would fail together like that
JUN.
01-25-2010 07:55 AM
thehatchninja
04-01-2004 03:10 PM
