All of you N/A guy's. . . .
Thinking of going N/A with my '93 Civic HB. Trying to get an idea on what to do. Post what you all think I should do. . . . . thinking about doing biult GSR. I'm trying to get into the 12's, don't care if it's high or low 12's. As long as I get there N/A. What do you all think?
Jeramy
Jeramy
Sushi Buffet Champion
Re: All of you N/A guy's. . . . (WykidEH)
GSR motor
B16 tranny
B16 pistons
Skunk2 cams
310cc injectors
Light flywheel
Skunk2/Type R ITM
64mm TB
That's a start.
B16 tranny
B16 pistons
Skunk2 cams
310cc injectors
Light flywheel
Skunk2/Type R ITM
64mm TB
That's a start.
Solbros Owns Me
Re: All of you N/A guy's. . . . (GapxGuy)
more worth it to just get an ITR swap. LSD, close tranny, high compression, blah blah. Run 13 flat with slicks and good driving in a light hatch.
big strong guy
Re: All of you N/A guy's. . . . (Emerica)
JDM ITR swap
Try some mild cams ie... Skunk2 stage 1, Or Toda A spec
Should yeild ~ 190hp tuned
Perhaps 12s in race mode!
eric
eric
Re: All of you N/A guy's. . . . (rainmanEK)
the cheapest way to hit 12's is your hatch is gonna be...
top half...
gsr head
portflow valvetrain
skunk2 stage 2 cams
skunk manifold
type r throttle body
310 injectors
skunk cam gears
bottom end....
ls block
ls rods
ls crank
ctr pistons
make sure its all balanced....
throw a hondata in there and you are set.
b16 tranny with a diff and your in the 12's on a budget....
top half...
gsr head
portflow valvetrain
skunk2 stage 2 cams
skunk manifold
310 injectors
skunk cam gears
bottom end....
ls block
ls rods
ls crank
ctr pistons
GSR motor
B16 tranny
B16 pistons
Skunk2 cams
310cc injectors
Light flywheel
Skunk2/Type R ITM
64mm TB
That's a start.
B16 tranny
B16 pistons
Skunk2 cams
310cc injectors
Light flywheel
Skunk2/Type R ITM
64mm TB
That's a start.
Re: All of you N/A guy's. . . . (vtecdoc)
top half...
gsr head
portflow valvetrain
skunk2 stage 2 cams
skunk manifold
310 injectors
skunk cam gears
bottom end....
ls block
ls rods
ls crank
ctr pistons
top half...
gsr head
portflow valvetrain
skunk2 stage 2 cams
skunk manifold
310 injectors
skunk cam gears
bottom end....
ls block
ls rods
ls crank
ctr pistons
Re: All of you N/A guy's. . . . (B18C-EJ1)
Ok, well I don't know how much I'm going to spend on the set-up.
What I have right now is:
GSR block
LS crank
GSR head
GSR tranny w/ITR LSD
Skunk2 intake manifokd
DPR O/B trttle body (64mm)
What I'm thinking is running:
Eagle rods (LS)
Wisco 81.5 H/C pistons
Portflow head work
Toda spec "B" cams
w/ valvetrain
Skunk2 valves
JDM ITR header
Hondata
Spoon cam gears
Does that sound good?
Jeramy
GSR block
LS crank
GSR head
Eagle rods (LS)
Portflow head work
Toda spec "B" cams
w/ valvetrain
Skunk2 valves
JDM ITR header
Hondata
Spoon cam gears
Jeramy
Unceasing Measure
^ROFL
B19CivicHB has a 92 EH2 with JDM GSR swap. He's staying all motor and has done the following to get there:
Overbore .020
JE 12.5:1 CR pistons
Eagle Rods
Balanced and blueprinted assembly
Drag Clutch, JUN flywheel
AN-R drag Header
Full 2.5 inch exhaust, Magnaflow, Catco 2.5 inch high-flow cat
AEM CAI
MSD SCI ignition
Magnacore wires
Factory LSD (JDM GSR motors own )
Z10 radius arms
Walbrough fuel pump
Fluidyne radiator
Kosei K1's with Dunlop ZR-rated tires
Soon to have a gutted intake manifold, Ti springs and retainers, Honda-Saver cams, Honda-Saver valves, AEM Camgears, Hondata S200, ported and polished, makes power up to 10, 500 rpms and the forged internals can handle it
If we can hook up, we're looking at easy 12's...low 12's with practice and traction.
Overbore .020
Eagle Rods
AN-R drag Header
AEM CAI
MSD SCI ignition
Magnacore wires
Z10 radius arms
Walbrough fuel pump
Fluidyne radiator
Re: All of you N/A guy's. . . . (vtecvoodoo)
..and you`re at 89%, which means I value your opinion as much as a pile of dogshit.
Drive-thru...
Drive-thru...
i got a friend that hit 13 flat on drag radials
with bone stock type r swap and bolt on
imagine with slicks!
Re: All of you N/A guy's. . . . (rathead-ek)
this ******* web site is filled with ******** and riceboys
i dont know why i waste my time
