Are all EG Front spindles the same?
Re: Are all EG Front spindles the same? (BlueIntegraBoy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlueIntegraBoy »</TD></TR><TR><TD CLASS="quote">Nope. All CX, VX, DX, LX, and 92-93 Si are all the same. I suggest getting knuckles from 94-01 Integra or 92-95 Civic EX/Si with ABS.</TD></TR></TABLE>
Why ABS?
Why ABS?
Re: Are all EG Front spindles the same? (-Gary-)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by -Gary- »</TD></TR><TR><TD CLASS="quote">
Why ABS?</TD></TR></TABLE>
Because the non-ABS Si's didn't have the larger front brakes.
HT Order of Merit
Are you sure thats correct? From what I know, the ABS versions of the Civic, shared the same knuckles, rotors and calipers as ALL 94+ Integras, execpt the ITR of course.
On the 92-95 Civic, the CX, VX, DX and LX have a different front knuckle and smaller brakes. (rotors and calipers). The only model's which had LARGER front brakes were the Si hatchback, and the EX (Maybe LX too...) model with ABS, which were the same as Integra brakes.
All 94+ integra brakes are the same size, except the ITR.
Re: Are all EG Front spindles the same? (drktorn)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by drktorn »</TD></TR><TR><TD CLASS="quote">depending if you have a 1.5 or 1.6 the axles are different.</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM_Ej »</TD></TR><TR><TD CLASS="quote">Are you sure thats correct? From what I know, the ABS versions of the Civic, shared the same knuckles, rotors and calipers as ALL 94+ Integras, execpt the ITR of course.
All 94+ integra brakes are the same size, except the ITR.</TD></TR></TABLE>
This is what I said above. All EXs and Si's with ABS (94-95) have the same knuckles as the Integra.
my buddy has a gsr swap into his vx. i found him a nice pair of 94+ Integra spindals, complete. he is going to swap them over once the front camber kit comes in, does this mean he can run regular non-modified integra axels?
cute little bastard
Re: Are all EG Front spindles the same? (JDM_Ej)
Yup. Only thing is, in 92-93 no Civics had ABS IIRC (or passenger airbag) like BlueIntegra already said
Re: Are all EG Front spindles the same? (SkoundrelUSA)
I found a set that were pulled from a 92 civic 4dr EX with ABS, according to the seller. I bought a complete wrecked 93 GSR with low miles and plan on swaping in the B17, anyone know if the axles with match up?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlueIntegraBoy »</TD></TR><TR><TD CLASS="quote">Because the non-ABS Si's didn't have the larger front brakes.</TD></TR></TABLE>
Listen to this guy, he know's his ****!
Re: Are all EG Front spindles the same? (GReatEDDY)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GReatEDDY »</TD></TR><TR><TD CLASS="quote">I found a set that were pulled from a 92 civic 4dr EX with ABS, according to the seller. I bought a complete wrecked 93 GSR with low miles and plan on swaping in the B17, anyone know if the axles with match up? </TD></TR></TABLE>
You need 94-01 Integra axles
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlueIntegraBoy »</TD></TR><TR><TD CLASS="quote">You need 94-01 Integra axles</TD></TR></TABLE>
Depending on what 1/2 shaft he uses.
well my roommate has a 92 civic with a gsr swap. we are going to swap over 94+ gsr front spindals, on his ride. i take it he can now just use plain integra axels, or is this incorrect.
Re: Are all EG Front spindles the same? (dem0nk1d)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dem0nk1d »</TD></TR><TR><TD CLASS="quote">well my roommate has a 92 civic with a gsr swap. we are going to swap over 94+ gsr front spindals, on his ride. i take it he can now just use plain integra axels, or is this incorrect.</TD></TR></TABLE>
This is correct, use any 94-01 Integra axle
alexb18c1
07-10-2008 04:04 AM
JoJoNz
19
04-18-2005 02:37 PM
