Alignment needed when swapping out drums with discs?
Old 12-09-2003, 07:58 PM
Fuster_Cluck's Avatar
Default Alignment needed when swapping out drums with discs?
GSR rear discs going into my Eg. Going to use stock LCA's.
Thanks!
Old 12-09-2003, 07:59 PM
2000blackgsr's Avatar
Default Re: Alignment needed when swapping out drums with discs? (Hybrid93Hatch)
Yes, its probably a good idea.
Old 12-09-2003, 08:17 PM
Default Re: Alignment needed when swapping out drums with discs? (96coupe)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 96coupe &raquo;</TD></TR><TR><TD CLASS="quote">Yes, its probably a good idea.</TD></TR></TABLE>
Ok, they go on after the new year because I am broke as $hit with X-mas and every other damn thing going on.
Old 12-09-2003, 08:28 PM
kommon_sense's Avatar
yep, you need an aligment.
Old 12-09-2003, 09:28 PM
pdiggitydogg's Avatar
shouldve gotten a lifetime alignment from your shop
I get free alignments no matter what I do
Old 12-10-2003, 05:19 AM
Default Re: (pdiggitydogg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pdiggitydogg &raquo;</TD></TR><TR><TD CLASS="quote">shouldve gotten a lifetime alignment from your shop
I get free alignments no matter what I do</TD></TR></TABLE>
How much did that run you? I pay $48 just to get the front and rear TOE adjusted at the shop
Old 12-10-2003, 05:29 AM
jolt-tsp's Avatar
Default Re: (Hybrid93Hatch)
You don't really need an alignment.. I aligned myself just by eyein' it, then took it to a shop. I was .1 degree off on the drivers side and .2 on the passengers. If you have the cash to align it though, it can only help.
Old 12-10-2003, 06:04 AM
scratchy's Avatar
when ever you take the suspension apart its a good idea for an alignment but that can also be expensive but slap it back together and see how it drives then go from there.
Old 12-10-2003, 07:23 AM
migs's Avatar
Default Re: (jolt-tsp)
LOL
A degree and 0.2 is alot in terms of alignment being out.
Good try though
Old 12-10-2003, 07:31 AM
92b16vx's Avatar
Or just swap out the spindles, more of a pain in the ***, but you don't have to disconnect the compensator arm.
Old 12-10-2003, 08:04 AM
jolt-tsp's Avatar
Default Re: (Migs)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Migs &raquo;</TD></TR><TR><TD CLASS="quote">LOL
Good try though </TD></TR></TABLE>
.1 degree, not a whole degree. After computer align I was at .04 and .06 degrees. I'm not trying to downplay an alignment though, just saying if you have to go a few hundred miles to save up for one, it's no biggie.
Old 12-10-2003, 08:08 AM
SloCivicHMM's Avatar
don't disconnect the upper control arm or the toe arm from the car and bolt everything back up and it should be back like stock or like it was before.....
do you get what I'm saying? the TA bolts up back in the same possition it was before.........that way you don't have to swap spindles and ****.......
Old 12-10-2003, 08:11 AM
NonovUrbizniz's Avatar
Default Re: (SloCivicHMM)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SloCivicHMM &raquo;</TD></TR><TR><TD CLASS="quote">don't disconnect the upper control arm or the toe arm from the car and bolt everything back up and it should be back like stock or like it was before.....
do you get what I'm saying? the TA bolts up back in the same possition it was before.........that way you don't have to swap spindles and ****.......</TD></TR></TABLE>
I did that when I did mine... the driver side was fine the pass. side is WAY WAY out...
GET IT ALIGNED... you CAN NOT "eye it"... reliably at least...
Old 12-10-2003, 08:13 AM
Default Re: (NonovUrbizniz)
that means your TA was bent.....I know mine is bent right now after my accident....I got an SRR toe arma nd the alignment shop said everything was fine and back to spec.....it droves fine.......
Old 12-10-2003, 09:48 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hybrid93Hatch &raquo;</TD></TR><TR><TD CLASS="quote">
How much did that run you? I pay $48 just to get the front and rear TOE adjusted at the shop </TD></TR></TABLE>
It cost $120 for lifetime...only $20 more than the 3 service one. I figured since Im running the old style skunk2 front camber (which is known to have probs) I would get the life time so I could get the current alignment, one for the rear disc swap, one for the skunk2 swap when they go bad (and I think they will), and then anytime I want after that.
GRANT!
10-31-2006 07:05 PM
all_out_jdm
03-01-2006 12:45 PM
Jaydeep
09-15-2004 11:56 AM
SPiFF
06-14-2004 08:48 AM
2 point 0
05-01-2004 09:59 PM
Quick Reply: Alignment needed when swapping out drums with discs?
