alignment
Old Sep 21, 2009 | 10:21 PM
hatch_'s Avatar
Default alignment
got my suspension and camber on the other day. took the car to get an alignment done this morning. but for some reason, the car still wants to steer to the left. isn't an alignment supposed to straighten the wheels and whatnot? i can notice an improvement after the alignment. but i feel like it wasn't a good enough job. is this normal?
Old Sep 21, 2009 | 10:25 PM
red_EF9Si's Avatar
Default Re: alignment
check your tires for any abnormal bumps, bubbles etc. also make sure they're inflated properly and evenly. i would also check out your suspension hardware such as balljoints, tie rods, steering rack, axles, cv joints etc. could just be something that is causing the car to steer in a certain direction which is beyond the scope of an alignment. BTW what kind of suspension and camber kit is it?
Old Sep 21, 2009 | 10:29 PM
worlds-slowest-EG's Avatar
was your driver side window down? small cars rely alot on aerodynamics and even an open window will cause a pull to one side or the other.
Old Sep 21, 2009 | 10:33 PM
red_EF9Si's Avatar
:facepalm:
Old Sep 22, 2009 | 02:57 AM
grumblemarc's Avatar
The Grumpiest
OMG.
Old Sep 22, 2009 | 03:06 AM
hondamark35's Avatar
check the brakes for draging. i like to go to that first because it can be check in the driveway (as opposed to taking it to an alignment shop again..) make sure the caliper slides aren't sticking. relube if needed. look for more wear on one side than the other... obvious things.
it's good to check the tire wear as well as long as they are in the original position and havn't been rotated.
Old Sep 22, 2009 | 09:10 AM
andyfee's Avatar
lol hell yes its true.
when i smoke a cigg my hatch wants to make a U turn because when i ash my cigg
with my arm out the window and it throws off the aerodynamics.
Dam little cars lol
Old Sep 22, 2009 | 09:12 AM
American.Graffiti's Avatar
Check these.
Old Sep 22, 2009 | 11:38 AM
hatch_'s Avatar
i checked my tired this morning and i have a bubble on my rear passenger tire. i hope this is what's causing it. should i get this fix asap?
Old Sep 22, 2009 | 12:41 PM
ASAP- yes
fixed- no
bubbles can't be fixed. you need the tire replaced. i would pick the worst of the remaining three and have it replaced as well. it's always best to do two tires at a time, and having the newest/best on the front.
CreaseKeeper28
Suspension & Brakes
12
Jul 20, 2009 12:00 PM
soclean1k_JDM
Suspension & Brakes
Jun 30, 2009 05:26 AM
Calsonic
Jan 5, 2005 09:05 AM
vtec94
Feb 12, 2003 09:39 AM
Type R1
Apr 24, 2002 05:14 PM
