Air leaking in cabin..
Hey,
I can hear alot of air leaking in tru the door seals on my civic. Specificly on the opening side of the FD door and the parallel side of the RD door. What can I do about this?
fd=front driver side
rd=read driver side
rd=read driver side
The window molding may need to be replaced. My passenger side window sits a few inches on top of the rubber molding after the window was replaced.
Yours may be dried which is causing the air to leak in.
Re: ([civic])
I think I need to get an automotive stethoscope to make sure it's not coming from the window, but I don't think it is. I was thinking new seals also, but wanted to ask to see if there was any trick or shortcut I could employ to fix the problem first.
I have already tried using additonal weatherstriping, the thick black sponge strip on the car frame where the door strip seals to. Didn't work good enough really.
I guess I am spending $100 for new weatherstriping.
Re: Air leaking in cabin.. (Paprika)
I have the same problem and when I go through a car wash water trickles in. It sucks. Also when I have the door fully shut I can push on the top left side and the door will move about a half inch anyone know how to fix that. Found out previous owner slammed the door very hard and I guess broke something.
