Air/fuel gauge
Air/fuel gauge
I have an air/fuel gauge I wanna hook up. Any one install one before? I'm installing it into an eg with a b16 turbo setup. My gauge has a grey, red, and a black wire coming out of it. I figuerd red=power ,black=ground, and grey=02? correct? Which wire on the 02 sensor do I connect the gray wire to? What's the best way to connect it?
Re: Air/fuel gauge (sicky)
I know it's not accurate, it was given to me. I just have an empty hole where a gauge goes so I might as well fill it up with the gauge. It also looks cool!
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sicky »</TD></TR><TR><TD CLASS="quote">You just purchased a nice waste of money if you don't have a wide-band o2 sensor.</TD></TR></TABLE>
this is very true.
those gauges are junk anyway, by the time it reads red its already to late!
this is very true.
Re: Air/fuel gauge (smokingemcee)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by smokingemcee »</TD></TR><TR><TD CLASS="quote">I know it's not accurate, it was given to me. I just have an empty hole where a gauge goes so I might as well fill it up with the gauge. It also looks cool!</TD></TR></TABLE>
It is your car, but why bother? If you can afford turbo, you can afford proper gauges. Hooking up a A/F gauge just because it looks good and you KNOW it wont give you any reliable results is stupid and is what some people would call rice. I prefer not to call it that...I just call it stupid.
When I did my turob install, I bought my gauge pods by what gauges I was goign to run, not oh **** I have a 3 gauge pod with a hole, better put a light show in there. Might as well put a neon in there..less hassle
H-T White Ops
put an EGT/oil/fuel/water temp/etc gauge int he empty hole. Not some fancy light show. An AF gauge hooked up to a narrow band O2 sensor is about as useless as ***** on a boar.
Re: (IslandSi)
since it was given to you for free, sell it on ebay, make some money you can use towards a better gauge. im sure you already have a boost gauge. I personally have an EGT, boost, volt, oil temp and oil pressure.
