My lil grey hatch with broken valves! (pics) :)
Old 09-01-2010, 05:00 PM
tales sol's Avatar
Default My lil grey hatch with broken valves! (pics) :)
c
Old 09-01-2010, 05:21 PM
rs2606's Avatar
Default Re: My lil grey hatch! (plenty of pics) :)
Ouch is that #1 or #4?
Old 09-01-2010, 05:35 PM
tales sol's Avatar
while it was out of action i decided to have it resprayed in the original pewter grey met.
Old 09-01-2010, 05:37 PM
tales sol's Avatar
ouch on the pocket, it was a JE piston, #4 if i remember right!
Old 09-01-2010, 05:41 PM
tales sol's Avatar
Default Re: My lil grey hatch with broken valves! (pics) :)
back together before i painted the ssr type m wheels
Old 09-01-2010, 05:46 PM
habib's Avatar
Very clean
Not tryin to thread jack but you got lucky, i dropped two valves and this was my result....
Old 09-01-2010, 05:51 PM
tales sol's Avatar
Originally Posted by habib
Very clean
yea i feel ur pain, wait and see what comes next lol
Old 09-01-2010, 05:55 PM
tales sol's Avatar
only on the road a couple of days and it dropped a valve!
iv no pic of the head here, i will take one tomoro
Old 09-01-2010, 06:12 PM
tales sol's Avatar
a pic with the temporary rota flashbacks while i was sandblasting and painting the ssr's.
and how it looks now!
Old 09-01-2010, 06:20 PM
HatchVX's Avatar
Man you have gone down a rough road, but its looks like its getting better for you. Keep it up.
Old 09-01-2010, 06:40 PM
tales sol's Avatar
thanks man but thats only half the story of bad luck really, heres my post in the a thread in the all motor section the other day when someone asked about catastrophic engine failure!!
my record so far! :O
had stock block jdm itr motor in my del sol, few bolt ons and skunk stg2 tuner cams and power fc, had a head on collision with an audi a6, (ouch) so reshelled it into an eg,
ok so enough bout that, it eventually spun a big end after much abuse so i decided to build it,
JE 12.2:1 pistons, eagle rods, eagle crank, acl race bearings!
head had some kms valve springs and crower 63402 cams and along with some other bolt ons and stuff,
it ran great for a long while but after doing some work one night and i was tired and not paying attention, i timed the ****er up wrong, was ok off vtec, came on vtec and.... tick, tick, tick boom!!
snapped valves off in the head ruining the head, bore and left holes in the piston! not nice, my own fault i know but the story continues!!
ordered a new piston and got a block, put it all together and went for it again, no sooner had i done 1000 miles something was up, the clutch pedal started to stop coming back up and wasnt working properly!!
shortly after the motor locked up solid, i felt like crying, ha, after stripping it down it was clear what had happened, i had ****ed up again from not paying attention i had fitted the thrust washers in backwards, they quite obviously wore away very quickly and they simply fell out and locked the crank solid,
damage from this **** up? ruined eagle crank and ruined block!
but try and try again is what i do so.........
got another block, got a stock crank and went again, i forgot to add that after i timed it up wrong i got a set of kms valves for the head too,
which leads me to "what happened next".........
all back together again and running sweet, decided to go for a run,
flat in 4th and went to pull 5th, on the gear change it hit the flat shifting limiter of 6k rpm, let out the clutch in 5th and it sounded anything but good!
head broke clean off one of my intake valves, rattled around the cylinder, broke and exhaust valve and maimed the piston, bore and head!
so what did i do then?? :O went AGAIN!!!!!!
got ANOTHER head and got a port/polish job done, 4 new kms vales to replace the mangled ones, got the block bored out to 82mm and ordered up a nice shiney set of wiseco 12.5:1 pistons! :D
its been together now for the last couple of weeks and going great so i ask everyone to wish me luck and say a prayer this time as im sick of spendin so much money!
might i add that each time its been running its ran like a champ and kicked ***!!
Old 09-01-2010, 06:51 PM
tales sol's Avatar
also, has anyone any idea what times i can expect on the quarter mile with a setup like that or dyno numbers too?
the car will be pretty stripped out for the track too
Old 09-02-2010, 01:03 AM
Master Detailer
98civdx's Avatar
Damn you have terrible luck lol
I remember when my friends crank broke at the track, that was some ****!
Old 09-02-2010, 03:33 AM
tales sol's Avatar
what kind of power was he runnin to break the crank?? :O
iv seen an evo break one but the crank had big miles on it
Old 09-02-2010, 11:48 AM
Master Detailer
98civdx's Avatar
1000+, Eagle crank lol
Old 09-02-2010, 05:47 PM
tales sol's Avatar
:O
anyone any input on figures guys?
Old 09-21-2010, 05:59 PM
tales sol's Avatar
well, went 1/4 mile the weekend
ran a 13.44 in the rain with a 2.2 60ft on toyo r888s!
could be a while before i get dry times
hope to get it dynod this week too!
Old 02-14-2011, 04:28 AM
jstoneracing's Avatar
Lookin well lad, quick yoke for a b16a
Old 02-14-2011, 07:30 AM
foo fighters's Avatar
looks like a SPOON drop-in filter, love that look!! What kind of paint did you use for the block?
Old 02-15-2011, 02:39 PM
tales sol's Avatar
it is spoon indeed!! its covered most of the time though!!
its just vht metallic black paint covered in aerosol lacquer!!
Dammit_Dan_954
05-17-2004 07:20 PM
Dammit_Dan_954
46
01-31-2004 11:09 AM
CheezeFrog
11-11-2003 02:20 PM
h46it
06-16-2002 10:17 PM
Quick Reply: My lil grey hatch with broken valves! (pics) :)
