ac removal
ac removal
Ok im removing my ac in preperation of the turbo setup. My question is, When i remove it, i want to remove the pulley and mount also, i dont see the point of have a belt turn it and doing nothing, dead weight and wasted space
what belt can i run, a dx belt, since dx's dont have ac or do they make a non ac belt for my ex?
any part numbers?
thank you
any part numbers?
thank you
Re: ac removal (tuck'd98)
Just remove the ac compressor, condensor, and fan and then cut the ac belt off. Ac belt, non ac belt, what are you talking about here? When you remove the compressor, the belt is going to just hang there so cut it off. Don't remove the lower AC mount. It is an engine mount and helps hold the engine in place.
