AC question
AC question
When I bought my HB, the guy had stripped the AC, there is a line that he cut that is on the firewall behind the battery box, any clue where that line goes and if that is gonna be a PITA to fix? Where I live and the fact I have a 13 month old son, I need AC, want the little guy to be able to ride with me!
Re: AC question (ImprtTuner88)
Well, the two lines that are on your firewall go into the evaporator, which is behind the dash. If he cut the evaporator, you could be fucked, if he just cut the line, then you will need to replace the line. There should be two, one is larger than the other. Pull your battery out, then get to the two or three bolts that hold your battery tray down, and check it out.
fullraceacura
05-20-2005 08:06 PM
