ABS Engaging At Low Speeds, HELP!
I was out late last night when I got into my car and I noticed my ABS was buzzing as I was crawling along for a good couple of hundred feet. My ABS light wasn't on while I was driving and it came on and off normally you turn the car on.
I did a fair share of searching and came to the conclusion that a couple of cracked teeth on my rear wheel hub most likely is the cause, I checked and I do have two or three teeth chipped a bit, would this sound right?
Anyway, I notice there's 3 fuses for ABS on my model (cdn '98 si) and I'm wondering if I pull them if that would disengage ABS? I want to at least drive the car safely to pick up a replacement for the wheel hub. Everyone I know is on holiday's and public transit is zero here.
I'd appreciate any help at all, thanks.
JRTegman987
12-02-2023 04:16 AM
gsrthomas
09-04-2005 08:22 AM
