okay so i got this 93 civic the other day and when u turn the car off and take the key out the ****** cd player is still workin.....how the hell does that happen??? if anyone knows wuts up then please tell me thanks guys
JdM_RaCeR
JdM_RaCeR
Re: ????????????? (JdM_RACeR07)
if its aftermarket it might not be wired up correct. pull the deck and check the wiring, if its correct, meter your acc. wire to verify if its holding 12v ( as you say it is) when the key turns off, if so problem is in the car, if not problem is in the deck.
Re: ????????????? (JSPECSIR)
someone probably wired it so it gets constant power. what you have to do is pull the radio and if i remember correctly snip the red wire and connect it to a acc. wire which is only on when the ignition is on.
does it stay on for like 5-10 seconds or does it permently stay on. My friend once wired his stereo with a larger gauage wire so when he turned his car off the stereo stayed on for 5-10 seconds and then it would shut off.
smartguysjt
12-17-2010 08:06 AM
laelowimports
03-06-2008 01:27 PM
