99 ek - h22a --> d15b7 mount problems
Hey guys I just swapped out my h22a out out of my ek and I'm swapping in a d15b7 with a z6 head into my ek. The d15 came from my 95 del sol 5 speed. I bought a set of mounts for the ek for a d series mounted them up and having trouble getting the motor to line up with the mounts. Am I using the wrong t bracket(del sol t bracket) also I have the correct 5 speed passenger bracket. Looks like the t bracket is to long? Also can I use they del sol axles in the ek? Any help appreciated!
Re: 99 ek - h22a --> d15b7 mount problems
I used the passenger and driver ek but I have heard the ek t bracket wont work for a obd1 d15 is yet true or do I need the t bracket for the ek d16?
I never narc'd on nobody!
The rear T bracket is dependent on the chassis, not the origin of the motor. Any D series in a 96-00 Civic will use the 96-00 D series T bracket. Any D series in a 92-95 Civic will use the 92-95 T bracket. Any B series in a 96-00 Civic will use a 99-00 B series T bracket. Any B series in a 92-95 Civic will use the 92-95 (or Integra) T bracket.
You need a 96-00 D series T bracket.
Ok thanks guys. Also can I run the axles from the del sol into the ek? I had recently put new axles in the del sol before pulling the d series.
Ok guys I got a 96-00 t bracket for a 5 speed and installed it and still not having any luck with my mounts lining up its like the motor still needs to move back. The mounts I ordered are very similar to the oem theey came from yonaka with a lifetime warranty and says they will work for a 96-00 wwith d or b series.
-Intl Steve Krew
Pictures would help immensely.
NARC, would the driver side post mount make a difference between the 5th and 6th gen chassis?
-Intl Steve Krew
Yeah that's exactly what I'm talking about.
I am almost 100% sure it'd need to be from a 96.
Reason being, the chassis mount is different in the EG/DC, and we have to use the EM1 mount in the 6th gen chassis to put in a b series and still use D series chassis mounts.
